Eibach Prokit 07+ Sedans
Old Aug 21, 2011 | 05:12 PM
eatsleepdrum's Avatar
check my garage for pics, I've got eibachs on stock shocks as well. heel/toe can be perfect although you're going to have a little bit of neg camber w/o a kit; no problemo because I like it like that. IMO I still need to put on 5-10mm spacers as well...
Old Aug 21, 2011 | 10:13 PM
lefizzet's Avatar
Just posted my spec sheet in another thread. Running eibachs with only rear camber kit
https://g35driver.com/forums/6071542-post18.html
Old Aug 21, 2011 | 11:11 PM
salvador312's Avatar
I keep forgetting to post my alignment sheet!! For sure today! When I get home! No camber arms here!
Old Aug 29, 2011 | 06:28 PM
Finally!! Alignment sheet, on stock 18"s, no camber arms, RWD!
Old Aug 29, 2011 | 06:32 PM
They did a great job keeping my TOES within specs!! That's what chews your tires!!
Old Aug 29, 2011 | 09:50 PM
AesonVirus's Avatar
My tires have held up just fine without camber kits.
Just keep everything else in proper alignment and you should be set.
I waited 3-4 weeks for my springs to settle when I installed mine and in those four short weeks, my FK452's were destroyed. Turns out, my Toe was a bit out and Toe kills tires overnight. LOL
Once I got the alignment, I've been sticking to corners like glue and I see VERY little inside edge wear... certainly not enough to be of a concern. By the time the inside edges are gone, the rest of the tire will be needing replacement anyway.
I dropped my car for looks alone but once I got a feel for what that negative camber gave me, there was no going back.
Enjoy the much improved handling it brings with the drop.
Old Aug 29, 2011 | 10:20 PM
rpm&my_G35's Avatar
How many miles so far and on what type of tires.
Are you running same size or staggered wheels on your X? You may have the advantage of rotating if necessary.
Old Aug 29, 2011 | 11:04 PM
Before alignment!!
Old Aug 29, 2011 | 11:12 PM
rpm&my_G35's Avatar
^ i'm thinking those were garbage before the inside wore/tore apart. I guess with your typical weather you can get away with using them until they look like racing slicks but were I live you gotta have some tread...always.
Old Aug 29, 2011 | 11:20 PM
Ahahahah they were literally slicks!! Los Angeles weather is always nice!! I was just showing the inside wear without alignment!
Old Oct 6, 2011 | 11:40 PM
pugz's Avatar
just dropped my 07 today and no camber kit. right at -1.8to -2 degrees of camber all around and rear toe was at 0.08 degrees.
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
wuppiedog
Aug 7, 2015 11:16 AM
Soumilg
Jul 23, 2015 09:26 AM
Soumilg
Jul 18, 2015 12:33 PM
