How much can i expect to spend on a nice set of brakes?
Old Mar 22, 2011 | 07:43 PM
Anton_Chigurh's Avatar
I am looking for a little better then OEM rotors and pads..thinking ceramic..how much will it cost for 4 rotors and pads? Should i upgrade at the same time..or can i buy fronts..then up grade backs like 2-5K later?
Old Mar 22, 2011 | 08:17 PM
sunny G-35 NYC's Avatar
if you look around the marketplace you'll find the stop tech rotor and pad combos around $600 for all 4. I was going to do this but I just upgraded to a new BBK instead
Old Mar 22, 2011 | 09:12 PM
Am i right in thinking that ceramic is the way to go? For performance and longevity?
Old Mar 22, 2011 | 09:46 PM
J2S2M's Avatar
Y not save up a lil more and pick up some Akebono's? I just installed mine this past Saturday and I am so happy with everything about them! They look great behind my wheels plus the pedal feel is so much more stable and grabby. I highly recommend if you can drop $1500 or get lucky like me to pick up an used set for cheap.
Old Mar 22, 2011 | 09:48 PM
Yeah i am NOT dropping $1500 for brakes lol
Old Mar 22, 2011 | 10:03 PM
J2S2M's Avatar
Keep your eye out for some used ones in the marketplace. That's where I found mine!
Old Mar 22, 2011 | 10:48 PM
dohturdima's Avatar
I bought Centric Premium blanks (rockauto.com) and Bendix CT-3 ceramic pads (Amazon.com). Haven't installed either yet as the OEM rotors/pads have been surprisingly resilient. Unless you are looking to upgrade to slotted rotors, this is the best bang for the $. Best part: Bendix pads come with a voucher for 1 free replacement, can send in for a new set once the previous set wears out. Nice lil' perk for a wear/tear item.
Old Mar 23, 2011 | 11:14 AM
djfarhan's Avatar
yes u r :P
Old Mar 23, 2011 | 04:15 PM
kool_yaar's Avatar
id say around ~$500-600 for premium rotors, just check out some sites i got mine from r1concepts.com
Old Mar 23, 2011 | 05:00 PM
djfarhan's Avatar
^ + 1 thats what i am planning to get
Old Jun 7, 2011 | 09:31 PM
rvanderwerf's Avatar
which pads did you get? did you get the premium slotted and x-drilled rotors?
Also, I've heard conflicting info on turning x-drilled or slotted rotors, is it possible? Some shops said no, other people have told me you can.
Old Jun 8, 2011 | 07:25 AM
celwin's Avatar
"Bendix pads come with a voucher for 1 free replacement, can send in for a new set once the previous set wears out. Nice lil' perk for a wear/tear item."
That's no longer the case. they stopped that offer
Old Jun 8, 2011 | 02:54 PM
wow, rockaudo prices are about 1/2 to 1/3 of the other place. I noticed the rotors say 'AWD Front' AWD Rear, etc, when I pick G35 sport option. I am assuming all of those rotors are the wrong size?
i.e.
CENTRIC Part # 12742080R More Information About this Part SportStop Drilled and Slotted Rotor
AWD; Front Right
$112.79
Add to Cart
CENTRIC Part # 12742080L More Information About this Part SportStop Drilled and Slotted Rotor
AWD; Front Left
I'm assuming those are not correct to use on a non-awd sport g35 08 ?
Old Jun 8, 2011 | 03:54 PM
lundy's Avatar
I got ATE's from the Tire Rack with Hawk ceramic pads. Stopping power isn't any different but these haven't warped yet like the OEM's do so I'm happy. I'm def going Akebono next time around. I'd like the confidence of more stopping power.
http://www.tirerack.com/brakes/resul...ourney+Package
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Frankieg35
Mar 20, 2016 09:42 PM
sahizzle110
Jul 29, 2015 11:36 AM
mushu
Jul 15, 2015 03:55 PM
