Best All season UHP Tires
Old Jun 8, 2011 | 09:52 AM
vqsmile's Avatar
Originally Posted by vince1
will the 245's fit on the front sport stock wheels?
yes, but poorly. If you are concerned about tire performance, then squeezing down a tire made for a wider rim isn't a good idea. You also would be changing the handling characteristics of the car a bit; better turn in, but more oversteer.
Can you rotate? with the wheel off sets
Yes, but you need to remove the bolt from the hub/rotor that prevents putting rears on the front.
Old Jun 8, 2011 | 09:54 AM
vqsmile's Avatar
Also, to get around the 225/50 tire size, have you considered going to a 235/50 and matching it with 255/45 on the rear?
Old Jun 8, 2011 | 10:08 AM
vince1's Avatar
I considered moving up to a 235/45 which is just slightly smaller than the rear. I was playing around with different sizes on the calculator. I think if +1 the rear along with the front I would be paying over $200. just to get the DWS. and would probably be cheaper to get the 960 A/S which is a top tier tire and probably a better all around tire. And that's my problem Either way I'll have to pony up the cash. I just wish I had a little more variety without having change.
Old Jun 8, 2011 | 05:58 PM
vqsmile's Avatar
... I just wish I had a little more variety without having change.
bahahaha . . . (paraphrasing) So you want things to be different, but without having to change!
That my friend, is human nature!
Old Jun 8, 2011 | 07:48 PM
vince1's Avatar
Yes!!! Exactly, and I want the best, more variety, cheap and delivered to my door.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
