torque spec for clamp that holds the front shock
Old Jun 18, 2011 | 12:20 AM
boostd7's Avatar
I have looked all over the manual and it's not in there. does anyone know this value. 2008x. There isn't that many diy for an x.
it's the brown rusty bolt at the bottom of the pic. thanks a mil.
Old Jun 18, 2011 | 02:15 AM
kool_yaar's Avatar
cabnt really judge from your pic on my tiny comp screen but looks like the only shock bolt which is 92ft/lbs to me
Old Jun 18, 2011 | 02:18 AM
kool_yaar's Avatar
Btw as per the FSM apparently its different for 2wd and AWD, i got this for the AWD but make sure and do at your own risk.
Old Jun 18, 2011 | 10:26 AM
boostd7's Avatar
****, is the front number foot/lbs what's the number in parentheses. (kg and newtons)? that means i have to go back and retorque all the bolts. still on lift. I just went by some of the diys and they had listed for example 28 lbs for the top of the struts.
here is the link that i found. it might be for a two door.
http://gshack.org/g/index.php?album=suspension
Old Jun 18, 2011 | 10:28 AM
boostd7's Avatar
right above the shock bolt where the Y ends there is another bolt that holds the strut to the body.
Old Jun 18, 2011 | 11:58 AM
boostd7's Avatar
Units INFOID:0000000001834590
• The UNITS given in this manual are primarily expressed as the SI UNIT (International System of Unit), and
alternatively expressed in the metric system and in the yard/pound system.
Also with regard to tightening torque of bolts and nuts, there are descriptions both about range and about the
standard tightening torque.
“Example”
Range
Standard
• THE SMALL ILLUSTRATIONS show the important steps such as inspection, use of special tools, knacks of
work and hidden or tricky steps which are not shown in the previous large illustrations.
Assembly, inspection and adjustment procedures for the complicated units such as the automatic transaxle
or transmission, etc. are presented in a step-by-step format where necessary.
Outer Socket Lock Nut : 59 - 78 N·m (6.0 - 8.0 kg-m, 43 - 58 ft-lb)
Drive Shaft Installation Bolt : 44.3 N·m (4.5 kg-m, 33 ft-lb)
I guess i was right. the link would be correct too. the first number in in newtons.......the last number in parentheses in in metric ( foot-lbs).
Old Jun 18, 2011 | 01:47 PM
kool_yaar's Avatar
^ yup thats right, my bad, it was SUPER late when i saw your thread so might have messed up. At least u go t it done.
Old Jun 18, 2011 | 02:21 PM
boostd7's Avatar
Still can't find the value. I will just go with 65 lbs
Old Jun 18, 2011 | 02:22 PM
boostd7's Avatar
I only paid like 19$ for thecd. That's why its missing ****
Old Jun 18, 2011 | 03:58 PM
soundmike's Avatar
I have a RWD Sedan There's no mention on the FSM for that plate, so as i noted it just torqued mine down to about 70 ft. lbs. It hasn't gone anywhere and is on there tight.
Old Jun 18, 2011 | 04:09 PM
boostd7's Avatar
Thanks. That's what I was about to do also. The awd and rwd aset up so different in tge front. Wonder why
EPG35
Aug 16, 2015 04:52 PM
Team STILLEN
Aug 10, 2015 08:17 PM
newg37
Jul 26, 2015 09:32 AM
