2007 G35S Rear Brakes
Old Aug 26, 2011 | 02:30 PM
stevem13's Avatar
I am getting ready to do a rear brake job on my 2007 G35 Sport. I was just curious to know what all tools are needed before I put the car in the air. Are any special tools required
Old Aug 26, 2011 | 03:03 PM
rvanderwerf's Avatar
are you replacing the rotors or taking them off to get resurfaced?
If you are just doing pads, all you need is a 7mm allen socket wrench. Just pull the plastic cap off to get to the socket, and remove it, it should slide right open. Also when the car is jacked up, and blocked make sure its blocked off and the parking brake is off use your best judgement there lol (i.e. dont do this on a hill)
If you do the rotors I think you gotta take the caliper off, there are 2 bolts holding it on. Mine on the front were a @!# to get off, even with the breaker bar. Use a coat hanger or something if you don't have a buddy, don't let it hang by the brake line. I -think- the calipers use a 22mm socket on the bolts.
rezendvous420
May 31, 2020 01:26 PM
laksjd84
Jul 24, 2015 05:12 PM
emorehs
Jul 17, 2015 09:45 AM
