New TSB for front brakes!!! ITB11-050
Old Oct 18, 2011 | 05:59 PM
G35power's Avatar
Class ific ation:
BR11-003
Refere nc e:
ITB11-050
Date :
August 9, 2011
G35/G37; FRONT BRAKE NOISE
APPLIED
VEHICLES:
2007-2008 G35 Sedan** (V36) – Sport models only
2008-2011 G37 Coupe** (CV36) – Non-Sport models only
2009-2011 G37 Convertible** (HV36) – Non-Sport models only
**Vehicles equppied with single-piston front calipers ONLY
APPLIED VINS 2007-2008 G35 Sedan: All
& DATES: 2008-2010 G37 Coupe & G37 Convertible: All
2011 G37 Coupe – AWD Vehicles built before: JN1CV6EL(*)BM 264118 / 13-Jul-2011
2WD Vehicles built before: JN1CV6EK(*)BM 215496 / 13-Jul-2011
2011 G37 Convertible - Vehicles built before: JN1CV6FE(*)BM 954311 / 13-Jul-2011
IF YOU CONFIRM
While traveling forward or backward at a slow speed, a squeal or sqeak noise is coming from the front brakes
when braking.
ACTION
Replace both front brake caliper sliding pins (one on each side of the vehicle) with the ones listed in the Parts
Information.
PARTS INFORMATION
DESCRIPTION PART NUMBER QUANTITY
Sliding-Pin 41133-JK00C 2
Old Oct 19, 2011 | 06:31 PM
djfarhan's Avatar
thanks for the info!
Old Oct 19, 2011 | 07:12 PM
G35power's Avatar
I have the some problem when driving backward,i tought it was pads but i guess no. called my dealer to see if they have part in stock.
Old Oct 22, 2011 | 06:27 PM
bat6wc's Avatar
Thank you for this info. This looks different than the TSB posted on myg37 for the same issue. TSB numbers are different at least. http://www.myg37.com/forums/tsb-tech...eak-noise.html
i tried going to the dealer for the TSB listed on myg37 and they said no because the number of pistons on my caliper was different. I have an XS. Will this one apply to me?
My brakes squeal constantly under medium braking and low speeds!
Old Oct 23, 2011 | 12:24 AM
G35power's Avatar
The tsb from myg37 doesnt apply to your car. Try this one,it will help since they will put new pads.
ITB09-009
2007-2008 G35 SEDAN, 2008-2009 G37 COUPE; FRONT BRAKE SQUEAL / SQUEAK NOISE
Squeal/Squeak noise from front brakes
Information from infinitihelp.com
Old Oct 23, 2011 | 12:28 AM
G35power's Avatar
PDF File!!!
File Type: pdf
Old Oct 23, 2011 | 12:29 AM
G35power's Avatar
Pdf
File Type: pdf
Old Oct 24, 2011 | 10:57 PM
bat6wc's Avatar
i see it all states in bold "single piston caliper only." thats what it states on the myg37 one. What brakes are single and what brakes arent?
Old Oct 25, 2011 | 02:13 AM
vqsmile's Avatar
This is only for the Sport brakes on the G35 sedans and the non-sport brakes on the G37 coupes, PERIOD.
There was never a G35 X model that had Sport brakes, even the XS.
Old Oct 25, 2011 | 09:24 AM
bat6wc's Avatar
so again, this does not apply to me then
Old Oct 25, 2011 | 01:08 PM
vqsmile's Avatar
^^ correct
Old Oct 25, 2011 | 02:08 PM
bat6wc's Avatar
^^ correct
Grrrrr. Great
Old Nov 1, 2011 | 12:51 PM
G35power's Avatar
Take it to the dealer and see what they say!
Im still waiting to do this TSB because they need to replace my steering wheel and right padel shifter is lose and this parts on backorder.
Grrrrr. Great
Old Nov 1, 2011 | 03:08 PM
vqsmile's Avatar
Im still waiting to do this TSB because they need to replace my steering wheel and right paddle shifter is lose and this parts on backorder.
The dealer will say that it doesn't apply to his vehicle.
Old Nov 1, 2011 | 09:07 PM
bat6wc's Avatar
yup, theyve already done that. im going to make another appt and see if I can demand a fix. new pads at least. the noise is driving me bananas
