A few different questions
Old Jun 27, 2012 | 05:29 PM
zoop425's Avatar
Whats up everyone! I have not been on here in quite a while so its good to be back. I have two questions.
1- there is this thud sound that sounds like its something bouncing around in the trunk but its not. I assume its a suspension issue. I am lowered on BC coils, any ideas?
2- I am ordering Forgestar F14F wheels soon and Im trying to decide on sizing. Im going to do 19x10 +15 in the back and 19x8.5 in the front but dont know what offset to go with. And because I have the x need to figure out which tires to go with for the right amount of stretch and function.
thanks!
Old Jun 28, 2012 | 08:28 AM
soundmike's Avatar
Are you going for function first, or form? +15 is pretty aggressive on a sedan, needing quite a bit of camber and a decent amount of drop.
Look at the photos of my old Rennen's here:
https://g35driver.com/forums/media-s...-c-10-20s.html
The fronts are 8.5 +24, rears (in the first post photos) are 10.5 +35 (later on replaced with +45s to address the rubbing). The rears on those rub with 285 rubbers. Camber was roughly -1.9(f) and -2.3(r).
Your x10+15 in the rears would extend and extra 15mm.
About that thud, not sure there. I have BC's myself, but no issues *knock on wood*. How stiff do you have things set? Are you sure it's not a loose spare tire, or the manual bags jumping around back there?
Old Jun 28, 2012 | 12:44 PM
zoop425's Avatar
the thud noise is something under my car or in the suspension im pretty sure. I currently at 15 in the front and back. With the new rims Im planning on tucking tire and resting at the lip. I also want function though, no more than -3.5 camber all around. I will definitely be stretching tires to make them fit but dont want to go to crazy here. I have seen people do 9.5+15 in the back no problem and I have seen people do 10.5+15 in the back but thats a bit to much. for the front I have seen people do 9.5+15 which I though was no aggressive enough so I figured with a 8.5 I should be around +5 or +7. thoughts?
Old Jul 31, 2012 | 02:11 PM
zoop425's Avatar
Can anyone chime in on this? Still trying to get opinions.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
