G37S Sedan Wheel Clearance
Old Mar 25, 2013 | 03:25 PM
zcmack's Avatar
Question G37S Sedan Wheel Clearance
Hi All
Looking to pick up a set of winter wheels for my 2007 G35S Sedan.
I found a set of OEM Sedan wheels from a 2009 G37S and everything I've read seems to indicate they would fit, but I wanted to double check before I pulled the trigger as I know the brakes changed between the 35 and 37.
Unfortunately I can't test fit before buying.
thanks
Old Mar 25, 2013 | 03:35 PM
apexi957's Avatar
http://lmgtfy.com/?q=stock+g35+wheel+specs
Old Mar 25, 2013 | 03:47 PM
zcmack's Avatar
Originally Posted by apexi957
I appreciate the thought but my question wasn't easily answered by googling (I have been looking at this all day...)
I know the wheels are the same size and have the same offset, but that doesn't necessarily mean the wheels are interchangeable. I'm curious whether the difference in brake assembly makes for any difference in wheel clearance.
Old Mar 25, 2013 | 04:13 PM
dominate's Avatar
If anything the 09 would have bigger brakes so I'm 99% sure the would be a direct bolt on.
Old Mar 25, 2013 | 04:24 PM
blnewt's Avatar
You'll be fine w/ those wheels, just have to get used to the uglier design compared to your 07s
Old Mar 25, 2013 | 04:33 PM
bluedevils95's Avatar
They will fit.
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
teamghost
Jul 28, 2015 04:52 PM
Ashton35
Jul 17, 2015 10:11 AM
