Akebono BBK over Sport brakes
Old Jan 8, 2014 | 07:41 PM
seekinganswers's Avatar
Hello,
Would there be a big difference between the Akebono BBK compared to a 2007 Sport sedan brakes for performance-oriented diving events. Thanks
Old Jan 8, 2014 | 09:22 PM
blnewt's Avatar
Akebonos have the much larger rotors for more rotor surface area for better braking & heat sinking. The larger aluminum calipers also provide much better heat sinking along w/ 4pot fronts. Daily driving the difference won't be as noticeable but on an extended day at the track the difference would be pretty dramatic .
Old Jan 8, 2014 | 10:50 PM
ChinkyChoy's Avatar
they also look cooler
Old Jan 8, 2014 | 11:01 PM
gary c's Avatar
Your factory sport brakes work great! Unless you're after the cool factor or intend to track your G, Akebono BBKs are a waste of your $$!
Gary
Old Jan 10, 2014 | 01:59 PM
KNS Brakes's Avatar
Akebonos will certainly help firm up the pedal on the street, and give you a bit better braking (if driving very hard)
Rotor sizes differ: Akebono fronts are 355mm and the 07-08 Sport front rotors are 330mm.
The larger sizes really help when on track, large rotors and calipers dissipate heat better and can handle more heat as well.
Compared to other calipers such as Brembo, AP or StopTech, Akebono calipers are priced very competitively.
-Nick
Old Jan 10, 2014 | 04:01 PM
WhosUrBuddiee's Avatar
Upgrade your fluid, lines and pads and your brakes will easily outperform stock Akebonos.
Old Jan 10, 2014 | 04:34 PM
totopo's Avatar
Originally Posted by seekinganswers
Hello,
Which track?
It would make a difference, though usually when it's someone's first time on a track, you don't drive hard enough to really work the brakes.
I would recommend getting decent pads (like hawk hp+, stoptech super-street, etc), and good dot 4 brake fluid (like ate 200, motul, etc.) and going to the track. If you like it enough to think about going back repeatedly in the long run, then start looking at upgrading your brakes.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
w4kj4k
Other Cars
Mar 6, 2016 08:06 PM
USAF_1013
Brakes
11
Feb 6, 2016 05:25 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
mushu
Jul 15, 2015 03:55 PM
