Rear brake rotor won't go back on
Old Mar 15, 2015 | 01:29 PM
RacerX113's Avatar
Hey guys,
I'm in the middle of a brake change and I'm having a problem getting my rear rotor to go back on. It looks like the e brake is getting in the way. Is there an adjustment for this? What am I missing?
Thanks
Doug
Old Mar 15, 2015 | 02:10 PM
vqsmile's Avatar
Originally Posted by RacerX113
Hey guys,
Thanks
Doug
First of all, are you putting the exact same rotor on that you originally took off, or have you changed it to a different** rotor?
(**including same type, but new or used)
Next, if you are putting different rotors on, have you measured the diameter of the drum bore?
Next, if the bore is the same as what it was on the original you took off, is the parking brake fully released?
Old Mar 15, 2015 | 02:32 PM
RacerX113's Avatar
not sure what was going on...e brake was off. after playing around with it for a bit it went back on. I think I might have misaligned it while banging on the rotors to remove them.
Old Mar 15, 2015 | 03:00 PM
vqsmile's Avatar
^^ Glad you got it.
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
RedBaronK
Jul 27, 2015 03:19 PM
apintojr
Jul 23, 2015 10:52 AM
emorehs
Jul 17, 2015 09:45 AM
