Aftermarket control arms
Old Feb 4, 2019 | 09:32 AM
EricF's Avatar
My '07 needs a new lower control arm or two. Any input on a good aftermarket brand? AC Delco and Beck/Arnley are available for roughly 2/3 of the cost of an Infiniti part. Thanks.
Old Feb 4, 2019 | 12:20 PM
cswlightning's Avatar
I recommend reusing your OE lower control arms and having the tired rubber bushings pressed out and replaced with Whiteline polyurethane parts which are stiffer and will last forever compared to buying rubber parts which will break again if you beat on them enough. Plus, it's even cheaper than buying new arms!
For the compression rod with the integrated balljoint either of those two brands you mentioned should be okay. Personally I went with the Mevotech Supreme compression rod mostly because of the blue boots, and it seems like a quality part. Just don't buy the cheapest one from any particular brand and you should be okay.
Old Feb 5, 2019 | 03:17 PM
EricF's Avatar
Thanks for the info. I went with B/A.
anmblackG
Steering & Suspension
Sep 2, 2012 01:18 AM
Pa1nandpleasure
11
Nov 13, 2011 06:16 PM
asdf
Nov 6, 2011 07:18 PM
turbomaxima
Archived Sales
11
Aug 11, 2006 10:55 AM
a2ncharm23
Archived Sales
Mar 7, 2006 04:34 AM
