Excessive bouncing in the rear after putting on new coils? - 2007 G35 Sedan
Old Jan 22, 2024 | 12:29 AM
Alan.vqhr's Avatar
Infiniti G35 Sedan Journey Trim, VQ35HR
So I just installed a set of Truhart Streetplus Coilovers into my 2007 g35 sedan. When I drove it with only the front coils on it worked fine, but after putting the back ones on it is extremely bouncy (To the point where going 30mph on a pretty flat road with just your typical cracks is getting you airtime out of your seat). I think it might be due to the coils having a shock and spring as one piece, with the g35 coming from factory with a separated shock and spring. This essentially made it to where I have 2 springs on the back of the car. Any tips to lessen this bouncing such as removing the seperate stock spring.
Old Jan 23, 2024 | 12:10 PM
Polishthrust's Avatar
Did you leave the rear OEM spring installed? The OEM spring needs to be removed when you install coils.
Old Jan 23, 2024 | 02:46 PM
Alan.vqhr's Avatar
Yes I left them in am I able to just remove them? or do a need a kit or different shorter spring to go in place.
Old Feb 2, 2024 | 01:10 AM
OEM springs should be removed.
Check out this thread: https://www.myg37.com/forums/g37-cou...coilovers.html
RecklessV35
Mar 22, 2022 01:43 PM
Kicknshift
Jan 18, 2015 03:12 AM
dragnby
Jul 31, 2012 11:19 AM
koyoki
Apr 10, 2007 11:46 AM
