DIY: Interior Trim Removal
Old Feb 28, 2009 | 06:08 PM
kregg's Avatar
Those "grey foamy connectors" are just the cables that actuate the door lock and release from the door handle & lock. If you look at where they connect to the panel they are just cables with barrels on the end and it you turn the cables away from the panel there is a slot the cable can slide out of and release from the door panel. THen the panel is fully released. This may not make sense until you look at it and its super simple.
Kinda similar to brake cables releasing from brake levers on bicycle if you ever worked on these.
Old Feb 28, 2009 | 09:50 PM
Wes_888's Avatar
Thx for clarifying Kregg. I guess I should have paid closer attention to how it removes. I just quickly looked at it and I was unfamiliar with it.
Also since I was able to remove the trim without removing the entire door panel aided my incompetence. LOL It did make my life harder doing it that way though.
Will check it out again when I do the other doors.
Old Sep 2, 2009 | 02:49 PM
G35plusKB24's Avatar
How would I remove the lower center console if I had a 5AT?
Old Sep 2, 2009 | 06:09 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
It will be similar.
The shift **** has a clip to remove though.
Old Dec 3, 2009 | 05:14 PM
Holmes35's Avatar
Nice DIY thanks man....also what type of floor mats are those?
Old Dec 15, 2009 | 02:38 PM
Rottten Appples's Avatar
dude thats pretty rad.. great highlighted marks in your own pics man. will definitely be using htis.
Old Dec 15, 2009 | 03:02 PM
InTgr8r's Avatar
....thanks
This is what I ended up with.
Old Dec 15, 2009 | 04:02 PM
holy crap that looks great.. do you have pics of the side trim?
Old Dec 15, 2009 | 04:09 PM
InTgr8r's Avatar
more here....
Carbon Fiber Interior Complete...
Old Dec 15, 2009 | 04:15 PM
YES!! that is clean as hell.. nice touch with the alcantara on the steering wheel too!!
Old Jan 7, 2010 | 07:11 PM
lmulion03's Avatar
nice thread. Just what I was looking for as I'm thinking of doing a custom trim. How hard is it to remove the trim. I'm a noob to all this stuff.
Thanks!
jesse
Old Jan 7, 2010 | 07:43 PM
lmulion03's Avatar
and also where can I find that manual that is on page 1?
Old Jan 7, 2010 | 10:28 PM
InTgr8r's Avatar
Thats from the FSM.
http://x.infinitihelp.com/forum/
Old Oct 23, 2011 | 05:38 PM
djfarhan's Avatar
thanks for the DIY!
Old May 29, 2012 | 12:24 PM
  #30
rpm&my_G35's Avatar
Ian, what happened to the pics?
