Just Installed FI HFC's on my 08 sedan.
Hey guys,
Just installed my Fast Intentions HFC's on my sedan w/stock exhaust. Install took about 2 hours and the car was on a lift. :) First Impressions: Really really RASPY for the first 30mins or so.... THEN... As if out of nowhere the CATS started to sound differently, smoother, and they definitely sound like a G35 coupe. I even put it up on the lift again and reved it to make sure there were no leaks or anything like that... Is there a break-in period for these Ceramic cats??? Ok, now the other thing I noticed... The Idle on my car is a little rougher. It fluctuates a little if barely any. I reset the ECU, did everything, but at idle i can tell that the Cats have definitely done something, via it be good or bad. Maybe I need a tune after I install my intake???? Anyhow, I really like the FI Cats and they seem to be breaking in and producing a better sound as I drive more and more. Has anyone else had the idling problem? Could you tell a small difference in your idle? Thanks everyone, DRes |
bump, thinking about getting HFC, mixed between FI and Berk. Wondering if the idle problem was resolved? also how many miles on them and how are the behaving now?
thanks |
Never had any idle issues after installing my Invidia HFC's.
I think it is an unrelated issue. I've seen hundreds of HFC/TP posts and this is the first time I hear of this issue. |
| All times are GMT -4. The time now is 06:14 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
