Adjusting muffler/exhaust drop
Old Feb 1, 2009 | 11:54 AM
soundmike's Avatar
Does anyone know, or have an illustrated guide from the FSM on how to adjust the drop of the muffler/exhaust?
The passenger side on mine is about an inch lower than the other, and it really bothers me.
Thanks.
Old Feb 1, 2009 | 01:32 PM
mishmosh's Avatar
I don't think there is an official procedure. There are a 3 hangers on each side towards the rear of the vehicle that you can play with. If it's the muffler tip, the rear hanger bracket (right above the muffler tip) can probably be lowered and some spacers placed where it bolts into. The other hangers may still be suspending the mufflers some so you might have to do this with the others.
Old Feb 1, 2009 | 01:43 PM
soundmike's Avatar
Thanks, i'll give that a shot. I was there a couple weeks ago looking at things but probably didn't see the brackets because of the covers. My temporary fix was to put a nut right under the rubber isolation points.
Old Feb 1, 2009 | 02:28 PM
terrycs's Avatar
1 inch is a lot and would bug me too. The dealer should be more than happy to check it out for you no charge under warranty.
Old Feb 1, 2009 | 04:13 PM
soundmike's Avatar
If all else fails, i'll give them a holler. They actually caused it when they replaced the failing cat.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
Fox843
Nov 7, 2015 05:43 PM
Rose M
Oct 12, 2015 10:00 AM
