G35 is tapping like a mofo
Old Aug 18, 2009 | 01:24 AM
daygostatvz's Avatar
G35 is tapping like a ****
My G35 has been tapping lately. I have no idea what the culprit is; it's only got 13K miles on it, and oil levels are fine. It happens when the engine is both cold and warm. Originally I thought it could be the valves for some God-forsaken reason or it could be that the Royal Purple was too slick. But now I have no idea wth it could be. So.... any ideas?
Old Aug 18, 2009 | 01:55 AM
pczavala's Avatar
what kind of gas you using?
Old Aug 18, 2009 | 02:03 AM
91. It doesn't sound like it's knocking, more like a tap, kind of like when older engines start tapping their rods in the cylinders.
Old Aug 18, 2009 | 03:17 AM
B L U E S L A T E's Avatar
Honda Accord
Does the tapping sound come from dash area when engine is on?
Check this out:
http://www.infinitihelp.com/Ownershi.../ITB07-007.htm
BTW, all these info can be found under 07+ sedan FAQs (stickied).
Old Aug 18, 2009 | 03:43 AM
No, it sounded like it was coming from the cylinder(s) closest to the nose of the car on the passenger side. I just started noticing it a few days ago. I thought that maybe the bearings were starting to go, but it's way way way too early for that... I'll see if I can take a video tomorrow.
Old Aug 18, 2009 | 09:24 AM
link's Avatar
take it to the stealer. it's covered under warranty right?
Old Aug 18, 2009 | 10:11 PM
MojoKidd's Avatar
I had a similar problem about year ago, turned out to be the clutch on the A/C compressor. It was fully covered under warranty. Good Luck
Old Aug 18, 2009 | 11:59 PM
johnnyzee's Avatar
if you have a manual (6mt), it could be your release (or throw out) bearing.
otherwise, link said it good, bring it to the dealer.
Old Aug 26, 2009 | 11:46 AM
ANMVQ's Avatar
Funny mine does the same thing cold or warm start sounds like the lifters tapping (DSM Car) LOL. My AC clutch also makes all kind of noise when I turn it on..
Old Aug 27, 2009 | 05:42 AM
Another weird problem just arose: when the car is in the "on" position without the engine running there is a really high pitched noise coming from the engine bay. I have no idea where it's coming from.
Dealer, here I come!
Old Aug 28, 2009 | 08:30 PM
pride's Avatar
my 07 G35 did that from the gitgo. I got it used with 27k. never paid much attention to it.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
