PROBLEM: overheating???
Old Sep 6, 2009 | 07:22 PM
_evilMonkey_'s Avatar
stright to the point.
checked coolant and it was below minimum.
filled it up little under maximum 2 weeks ago.
checked today and its way below minimum.
i see some coolant marks around the front engine bay area but dont see any coolant spilled marks on the bottom engine tray (plastic thing that covers the engine from the bottom).
HELP
Old Sep 6, 2009 | 07:42 PM
Q8y_drifter's Avatar
check all your hoses. if you don't see any leaks, take it to the dealer.
Old Sep 6, 2009 | 07:57 PM
seems very difficult to check ALL of the hose, specially the ones in the bottom... but i'll check
also, is it just me or does our G35 get hot after few miles of driving??
Old Sep 6, 2009 | 08:49 PM
Well not ALL hoses just the ones around the coolant mark area you mentioned
Old Sep 7, 2009 | 12:49 AM
Greekboy115's Avatar
If it is loosing coolant that quickly I would definetly bring it down to the dealer and get it checked out.
Old Sep 7, 2009 | 08:28 AM
kregg's Avatar
Check your oil, if it looks milky then there may be an issue with the head gasket. It is unlikely but there is a chance you are losing coolant there. You would also see a white smoke from your exhaust SpyHunter style....
Could be your heater coil too?
Old Sep 7, 2009 | 02:06 PM
kool_yaar's Avatar
^ very possible, stranger things have happened to brand new cars so i wouldnt rule that out.
FYI the cars do run on the hot side but the temp gauge should NEVER go over its normal just below middle temp mark, and the coolant should not be used so quickly i filled mine from between min and max to full over a year ago and still its full.
Old Sep 7, 2009 | 04:19 PM
Triton3.5's Avatar
If you take off the under tray, there is lots of access to stuff under the car,,,, But yes on the rapid warmup of these cars,, i was quite surprised how FAST they get to operating temp.. even in the cold months here.....
Old Sep 7, 2009 | 05:14 PM
gEE805's Avatar
thats when they are new...lol but give it some time.Then it will not be as quick.lol
Old Sep 7, 2009 | 09:12 PM
oil change was done about 3 weeks ago at the dealership. i had my service done at the dealership since day 1 so i drove it around thinking im good to go because i thought they would check all the gauge and fluid. also, i dont see any smoke coming out from my exhaust like "spyhunger" style, if i saw a smoke i would know... since i have HKS exhaust.
after driving 30-40 miles the fender tends to get really hot. the car is already hot because its black color but this car seems to get heated very fast and takes awhile to cool down.
G35Rican
Jul 31, 2024 01:37 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Jay123
Sep 28, 2015 08:42 PM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
