*NEW* Aluminum Collant Tank
Old Jan 6, 2010 | 04:46 PM
Defratos's Avatar
You're Despicable
P.S. your engine bay is F@cking CLEAN!!! you'd die if you see mine, it's got a huge layer of dust EVERYWHERE!!!
Old Jan 6, 2010 | 04:49 PM
2GoRNot2G's Avatar
Hahaha.... Thanks, man. It's amazing what a picture can hide. LOL
We actually get quite a bit of dust out here in the CA desert, but I try to blow off the engine with compressed air at least once a week and rinse it down with DI water at least once a month... that helps keep the build-up to a minimum... It's in dire need of a nice bath though.
Old Jan 6, 2010 | 04:50 PM
WhosUrBuddiee's Avatar
Remove those two stickers from your radiator cover. They are ugly.
Old Jan 6, 2010 | 04:51 PM
2GoRNot2G's Avatar
I know... I hate them too. I've actually got a CF radiator shroud coming for it, so I figured I'd just wait for that.
Old Jan 6, 2010 | 05:17 PM
bat6wc's Avatar
looks sick. hopefully you get the polished takedas because those K&Ns dont match anything now!!
Old Jan 6, 2010 | 06:42 PM
sunny G-35 NYC's Avatar
I was going to buy this but didn't know if it would be a direct replacement for the stock. How much coolant fits in there and how would I check it. And where did you get the after market hose kit I've been looking for one but didn't find any made for our cars.
Old Jan 6, 2010 | 07:30 PM
SxExCx's Avatar
^it is a direct replacement and has a slightly higher capacity than the OEM tank (less contours and notches) You pretty much just need to fill it to where the lines are on the stock tank and you are set. Whenever you need to check the level, just inscrew the cap and look inside. How often do you really check yours now?
Old Jan 6, 2010 | 11:51 PM
2GoRNot2G's Avatar
Exactly what I was thinking! And, that's actually the plan, Brian! Maybe your right, maybe we were separated at birth.
I used apx 16 oz of coolant water mix, which puts the factory tank up to the full line. The new tank can probably fit at least 4 times that amount. The level is easy to check... just remove the cap and look inside. There is actually a weld seem inside the tank where the tank angles that give you a good guide to use when judging if you need to add fluid or not. I have mine filled slightly past that seem... if you look in and the fuid level is below that seem, just add some distilled water.... that simple.
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
andresito7
Aug 1, 2015 04:53 AM
lilscsteve
Jul 21, 2015 04:01 PM
ZacDesu
Jul 14, 2015 11:13 PM
