Stillen Supercharger System progress thread
Old Jan 11, 2010 | 04:33 PM
Q8y_drifter's Avatar
hmmm, there were pics in my previous post and now they've been taken down. I guess Kyle showed too much too soon lol
Old Jan 12, 2010 | 11:38 PM
Cabad85's Avatar
awesome! subscribed
Old Jan 18, 2010 | 03:51 PM
More info from Stillen
Originally Posted by Stillen
After the decision was made to go with the Vortech Centrifugal Supercharger, work began on developing the kit. The engineers spent hours under the hood of our project G37 Coupe taking measurements, test fitting parts, and checking the tight clearances to see where they could put all of the necessary components. The new VQ37 has a very unique and challenging dual throttle body intake design. The STILLEN engineers have had great success with making big power off this design and a perfect example of that are the Generation 3 Intakes which offer up to 18 horsepower! However, the supercharger was going to require some creative thinking and once again, the engineers have pulled it off!
All of the engineering for this intake manifold has been done in-house. We began by developing several designs in our 3-Dimensional CAD programs which allow us to test virtual airflow and simulate installation and function on a “virtual engine.” Once the CAD drawings are completed the engineers “print” out a plastic part on our rapid prototype machine. This prototype is constructed out of a durable PVC plastic material and allows us to take our virtual work to the real world. With this prototype we can install the part on the engine to check our fit and finish, we can also use it for mock-up to run the intake piping, bolt up throttle bodies and route serpentine belts and more. We actually ran the car with this rapid prototype plastic manifold on the car which allowed us to check belt alignment and clearances while the engine was running.
Due to the overwhelming cost, we do not have an aluminum foundry in the back of our shop, so in certain instances like this some of our products have to be outsourced to specialists. These aluminum castings come back to our shop for final machining and finishing before being assembled with the intercoolers and the rest of the kit.
The company who does all of our castings also manufactures parts for some of the largest manufacturers in the industry including:
* TRD
* Roush Racing
* DART heads
* Chrysler
* Cosworth
* Bombardier
* Edelbrock
* and many, many more.
We are also very proud to say that they are based in the U.S.A. This is very important to STILLEN, as we feel too many companies these days outsource to other countries and we try our best to keep all of our manufacturing in-house or at least in the U.S.A.
The primary reason for engineering the new intake manifold is the inclusion of the intercooler in our Air-to-Water Intercooler System. Because of all of the heat built up during the compression of the supercharging process it is best to run some sort of intercooler system. There are two different types of intercooler systems, Air-to-Air and Air-to-Water. We chose to run an Air-to-Water system for many different reasons.
First question that usually comes up is: What is an intercooler, and what does it do?
An intercooler is essentially a radiator that cools the air compressed by a turbo or supercharger. Air-to-Water and Air-to-Air intercoolers essentially do the same job but go about it in two different ways, each having their pros and cons. The compression of the air by the supercharger or turbocharger causes the air charge to become superheated. When the air is heated it loses its density and also becomes less oxygen rich. An intercoolers function is to lower the intake air temperatures, thus regaining the density of the air and increasing the levels of oxygen in the air charge. Another benefit to the cooler air charge is the ability to run higher levels of boost, and more aggressive tuning without the concern of combustion anomalies.
Air-to-Water Intercoolers
Air-to-Water intercoolers are very similar to your cars cooling system. A water and coolant blend is cooled through a radiator/heat exchanger and is plumbed to the intercooler which is mounted inside the intake manifold. The compressed and superheated air coming out of the supercharger is blown across an intercooler which is being cooled by the water/coolant blend. This is where the heat is transferred from the charged air to the intercooler and removed back out to the heat exchanger. This thermal transfer cools the air at the last possible second before entering the engine thus guaranteeing the coolest air charge possible.
Air-to-Air Intercoolers
In an Air-to-Air system the superheated compressed air is cooled through the intercooler which is usually mounted up by the front bumper. The air then has to travel back to the intake manifold through metal tubing. This tubing is sitting inside the hot engine bay which is being heated by the air coming through various coolers such as, radiator, oil coolers, and also the heat coming off the exhaust manifolds, the engine block and the valve covers. The intercooler does remove a significant amount of heat but because the air has to travel back through the hot engine bay it is then being reheated before going into the engine.
Advantages / Disadvantages
A distinct advantage to an Air-to-Water intercooler is the condensed packaging. Air-to-Water intercoolers only require a relatively small heat exchanger in order to work efficiently. Think about how much outside air is coming through the front of your car. Now stick a heat exchanger or Air-to-Air intercooler in front of your radiator, oil cooler, transmission cooler, power steering cooler, and intakes. It quickly becomes clear that a large Air-to-Air intercooler is going to consume a large majority of the cool, fresh air coming in from the outside which also needs to be used to cool other vital components of your vehicle. Because an Air-to-Water heat exchanger is substantially smaller it does not need to consume as much cool air that can be used by other coolers for the car.
Air-to-Water intercoolers are actively cooling the water inside the cooling system by continually pumping the coolant utilizing an electric water pump. This means that it is effective and efficient at any speed. An Air-to-Air intercooler system greatly relies on the vehicle’s speed to generate sufficient airflow around the intercooler. This means that in real world conditions the Air-to-Air intercooler is not getting any air flowing through it while it pulls heat off of surrounding vehicles and off the road surface itself. At the same low speed or stop light situation the Air-to-Water system is actively circulating the coolant.
The only downside to an Air-to-Water intercooler system is the cost. Because there are two coolers, water pump and additional hoses and fittings for the plumbing the cost is a bit higher than just one large air to air intercooler. However, the performance benefits far outweigh the cost differences in our opinion for this application.
Old Jan 18, 2010 | 03:54 PM
this is looking good...
In the last update post we showed the new Intake Manifold and discussed the function of the Air-to-Water Intercooler System. Heres some more details on the design of the Intake Manifold and the engineering behind the STILLEN VQ37 Supercharger System.
As you can see we have relocated the throttle bodies to one side of the intake manifold. There are several reasons for this:
Intercooler Installation - Our intercooler is actually incorporated into the intake manifold. This dramatically decreases the intake air temperatures right before the engine receives the air. On the 350Z we found that the intercooler removed over 100 degrees immediately before the air entered the engine. There are other intercooler styles available, such as the water boxes that Vortech offers that are before the throttle body. Unfortunately on the VQ37 this would have significantly increased the cost, having two intercoolers and all of the associated plumbing, as well as space required in the engine bay would have been a major issue. Additionally, there is a lot of residual heat inside of an engine bay. Heat coming off of exhaust manifolds, the engine block, valve covers and more. Running two pipes across the top of all of this heat would only cause the air to re-heat inside the pipe prior to going into the engine. By cooling the air in the manifold immediately prior to its introduction into the engine we are getting the air as cool as possible.
Equal Pressurization - Yes, it would have been possible to simply use a Y-pipe design coming off the supercharger that went into the throttle body. The problem with this design is the different length tubes would cause an unequal amount of air entering the intake manifold on each side. Imagine a centrifugal supercharger mounted behind the headlight on either side of the vehicle. On the supercharger side, the air would only have to travel a foot or two to one throttle body, but on the opposite side the air would have to travel three feet across the front of the core support then another two feet back to the throttle body. This differential in distance means that one side of the plenum is seeing boost well before the other side, causing uneven air flow and pressure. This potentially could cause issues with tuning, power delivery, and could even cause additional turbulence inside the intake pipes. If both throttle bodies are open and one is receiving forced air but the other is still requiring the engine to be sucking air this will cause a large amount of turbulence inside the intake manifold. By equalizing the length of pipe that the air has to travel through, the engine will receive forced air in the intake manifold equally through both throttle bodies, thus reducing any turbulence.
Equal Air Distribution - It is very important to ensure that the air pressure is equal prior to going into the manifold, but it is even more important that the air is distributed evenly to each cylinder. The factory intake manifold has a very aggressive slope towards the front of the manifold. Combine that with the fact that the throttle bodies are aimed rearward, this could cause the front two cylinders to not get enough air thus causing the two front cylinders to run rich. By running rich and having more fuel than necessary in those cylinders it is actually hurting power and performance. By redesigning the intake manifold we are able to supply each cylinder with an equal volume of air which allows each cylinder to produce the most power possible and to work at its maximum level of efficiency.
Longer Runners - Another design that was incorporated into the intake manifold was a larger intake runner. By lengthening the intake runners we are able to increase torque which will help greatly with acceleration.
Here’s some higher resolution images of the 3D CAD renderings:
Old Jan 18, 2010 | 05:02 PM
suby01's Avatar
first quick questions that would make me want to follow this or not.
price+power?
Old Jan 18, 2010 | 05:15 PM
PhantomCoupe's Avatar
That is going to look pretty cool.
+1 price and power
Old Jan 18, 2010 | 06:50 PM
aooooo's Avatar
would this work on the awd model too?
Old Jan 19, 2010 | 02:45 PM
ANMVQ's Avatar
I would guess it would work on us, X cars as there are no under hood differences, But I'm not sure the T case can handle the added torque?
Old Jan 19, 2010 | 03:40 PM
mishmosh's Avatar
Man, what if that internal intercooler ever leaked--engine fubar'd? Pretty cool design I must say though.
Old Jan 19, 2010 | 03:56 PM
kmuniz78's Avatar
...Interesting concept to locate both throttle bodies on one side. Hmmm.....cost efficiency....
Old Jan 28, 2010 | 01:39 PM
tsui_san's Avatar
Teaser pic of the supercharger installed on G37: http://tinypic.com/usermedia.php?uo=...1I1Yh4l5k2TGxc
Looking good so far!
Old Jan 28, 2010 | 02:36 PM
jran76's Avatar
If you look at the actual install you will see it is most likely not for cost reasons, but more related to the actual routing for the intake pipes from the S/C to the manifold and their desired use of the I/C setup in the manifold. With their design there is really no way to get an intake pipe to the TB on the right side of the engine. So, it looks like their solution was to put both on the left side. This will increase the cost of the kit, and the R&D that went into it was not cheap.
GTM avoided this by putting the S/C "head" in the front-lower part of the engine, so it is not in the way of plumbing going to either TB....
Old Jan 28, 2010 | 02:42 PM
jran76's Avatar
I very small leak would probably not do any damage initially (people inject small amounts of water/meth via the manifold to cool intake temps all the time, and the engine survives). I big leak=hydrolock, or a small sustained leak over time would not be good....
The other thing too is that this is no different than the I/C they use on their VQ35 kits, or really any other air-to-water I/C (Vortech uses this on a lot of kits, but it is not part of the manifold).
Old Jan 28, 2010 | 02:56 PM
tsui_san's Avatar
Per Stillen's blog the relocation of the throttle bodies also increases the air/fuel efficiency to all cylinders. But this was done because of the location of the supercharger.
Old Jan 28, 2010 | 03:17 PM
  #30
kmuniz78's Avatar
Oh, I understand this, was being sarcastic. should have laid it on thicker. lol
