JWT is such a crappy fitting charger, and that joke of a heat sheild!!! After all the hype (false) i bought one for my 04 Sedan i had, but the fitting issue was exactly what you're experiencing now. Guess they haven't evolved any from the 2004 G35 design. What a shame.
I'm almost tempted to leave my stock intake on as someone suggested, but I guess time will tell when the mod bug starts to bite
. One thing I know for sure it wouldn't be a JWT pop charger.
. One thing I know for sure it wouldn't be a JWT pop charger.Quote:
The fact is that intakes alone don't offer much. You'll see a bit of an improvement through the higher RPM range but for the most part, expect nothing more than minimal gains. Short intakes need to be properly shielded to prevent too much engine heat from getting sucked in.
Even the long tubes offer only slight gains. Intakes should also be paired with a decent exhaust to get the most bang for the buck, both in terms of HP and sound.
Intakes can offer noticable gains on some cars, but the stock setup in the G is actually very efficient so there is not much that can be done to improve in this area.
The aftermarket tubes look awesome and the sound is killer. That should be your motivation. Any gains you get from it are just an additional gift. Dont go into it expecting any though. That was the question I was trying to answer.
well said. I will be the first to admit that a big part of the reason for this fun mod wasnt really for hp gains but more just cuz i think intakes sound and look bada$$ ! lol Originally Posted by AesonVirus
I'm not knocking these intakes.... I have intakes too. I just want to get that out there.The fact is that intakes alone don't offer much. You'll see a bit of an improvement through the higher RPM range but for the most part, expect nothing more than minimal gains. Short intakes need to be properly shielded to prevent too much engine heat from getting sucked in.
aftermaket exhaust might be next. any sugestions..??
Quote:
It's all a bunch of BS, the stock intakes are great. You should just throw a quality filter in each box and call it a day. Either way you look at it, metal pipes and exposed filters (small filters at that) aren't gonna do ****.
^+1Originally Posted by 03BaseSedan
Quote:
i am with you guys taht they dont add as much as they say but today at the airport i was reading a tunner magazine that did the basic 3 engine mods on a 350z and posted the dynos. it was at like 264 stock, exhaust bumped it to like 290, CAI bumped it to like 300, and osiris tune put it at 316, maybe 326? dont quote me on those numbers but they are in the same range, which sounds like pretty good gains to me!
And that was the same "test" that misquoted Tony from Motordyne.Originally Posted by R3diK3r0u5
because those are a cold air intake [longer tubes to place the filters basically behind the grill] which is supposed to provide more hp from the colder air. the stillen CAI requires modification to fit, you have to make a hole bigger. I will be getting the ijen CAI because it doesnt require modification.i am with you guys taht they dont add as much as they say but today at the airport i was reading a tunner magazine that did the basic 3 engine mods on a 350z and posted the dynos. it was at like 264 stock, exhaust bumped it to like 290, CAI bumped it to like 300, and osiris tune put it at 316, maybe 326? dont quote me on those numbers but they are in the same range, which sounds like pretty good gains to me!
Tuner math at it's best
50 to 60+ total gains
I have to agree thag stillen gen3 requires mod to fit..but end result inside engine bay and from outside the grill = priceless
And sound ofcourse
And sound ofcourse
