Which spark plug is OEM for 2007 sedan?
Old Apr 23, 2011 | 12:57 PM
eddystone's Avatar
What is the OEM plugs for a 2007 G35x sedan, is it 22401-5M015 = NGK PLFR5A-11? if not, please list the part number or do you recommend something better?
Old Apr 23, 2011 | 01:52 PM
kool_yaar's Avatar
they are listed as:
DENSO (Iridium-tipped type)
Standard type FXE22HR11
Gap (Nominal) mm (in) 1.1 (0.043)
Old Apr 24, 2011 | 02:15 AM
eddystone's Avatar
What plugs are recommended? I was told by infiniti that its NGK brand.
Old Apr 24, 2011 | 02:49 AM
kool_yaar's Avatar
1st gen used NGK and now they apparently switched to DESNO, either one is fine, imo any brand name plugs are fine as long as you get iridium, cause as is they are high quality and not that differentiable. NGK is good and reliable though
Old Apr 24, 2011 | 04:52 AM
eddystone's Avatar
So I am guessing the cheapest NGK Iridium is good enough? they cost about $20 a pair here. Is there only one NGK iridium, IX?
Old Apr 25, 2011 | 04:06 AM
gorillaclub's Avatar
what heat range is stock???
Old Apr 26, 2011 | 09:16 PM
eddystone's Avatar
What's the Nissan part number? My mechanic got 22401-5M015 but its not the right size.
Would NGK LFR5AIX-11 fit? I can't seem to find any info for NGK part number for the 2007 and 2008 sedans.
Old Apr 27, 2011 | 11:45 AM
eddystone's Avatar
I know the OEM spark plugs are Denso FXE22HR11 but would NGK LFR5AIX-11 fit?
Old Apr 27, 2011 | 12:13 PM
kool_yaar's Avatar
not sure but this might help, DIY
Old Apr 27, 2011 | 01:13 PM
eddystone's Avatar
On that thread someone with a 06 sedan said they had NGK PLFR5A-11 which is the same size as NGK LFR5AIX-11 but when I look up the size for the FXE22HR11 its smaller then the NGK? I been calling a bunch of part store and they all told me NGK LFR5AIX-11 will fit.
So these are OEM correct?
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_531wt_1165
Old Jun 17, 2011 | 01:53 PM
rkim210's Avatar
It won't fit for sure. I just tried on my car. The thread is too big. I'm out $40. lol
Old Jun 17, 2011 | 02:36 PM
eddystone's Avatar
What car do you have? I have a 07 sedan and its the exact same OEM stock plugs.
Old Jun 17, 2011 | 02:40 PM
rkim210's Avatar
I have the Sport sedan V36. The original plugs with the 14mm hex head had a smaller thread then the LFR5AIX-11 #4469
Old Jun 17, 2011 | 02:43 PM
eddystone's Avatar
Sorry I got confused for a sec. I ended buying FXE22HR11 and its was same as stock. I know for sure those NGK will not fit.
Old Mar 5, 2017 | 01:59 PM
Eclipse2G35's Avatar
Whats the life time on these plugs? My 07 with 107K miles still has the originals...
