Overbore is necessary?
Old Dec 13, 2012 | 02:11 PM
martalex's Avatar
Hi folks,
I'm sorry for my english, I'm from Ukraine
Explaine me please one thing: if I change my stock pistons to forged pistons do I need for sure an overbore? Seller of aftermarket parts advises me the pistons 96mm instead 95,5 mm stock and advises me a little overbore 0,02 ".
I didn't have such experience but my engine is in very good conditions. So I doubt... Take 96mm forged pistons or stock size forged pistons?
Give me please any advise. Thanks
Alex
Old Dec 13, 2012 | 07:50 PM
Phalanx's Avatar
I had my engine from another car rebuilt for racing purpose once in the past. However, that didn't turn out good. It's a long story and the end is my built engine was broken after 5000 miles. In your case, my opinion is if the cylinders are still smooth like a mirror with no scratches, you won't need to bore them. Technically, cylinders were coated with a very thin layer of special metalized material. When you bore the cylinder surface, that coated layer either get wiped out or thinned. That's why overbored/overhauled engines usually don't last as long as OEM engines.
To summarize what I said, inspect the cylinders carefully to see if they are in near perfect condition. Only overbore the cylinders If there are scratches or damage on them.
Old Dec 14, 2012 | 02:43 PM
martalex's Avatar
Thanks, I'll follow your advise
My cylinders are OK so I'll use standart size pistons without overbore.
Old Dec 16, 2012 | 11:47 PM
Q8y_drifter's Avatar
I don't see the need to overbore if you have the choice to go with stock size pistons.
Old Dec 16, 2012 | 11:56 PM
SUMATIC's Avatar
agreed with Q8y_drifter.
you have the option to go with the forged pistons at stock size. so why not just do that.
Old Dec 17, 2012 | 02:35 AM
martalex's Avatar
GTM has advised me to use 96mm pistons with a small overbore but after your questions (and on other forums) I've decieded to use standart size pistons.
The question was if I need overbore in general? Most people doesn't advise me to overbore so I've choosen standart size forged pistons.
dougk12
Engine - Complete Motors
Jun 13, 2015 09:01 PM
sandy@forged
Engine-Vendor
Sep 11, 2009 05:22 PM
jl4punch2
71
May 6, 2009 12:31 AM
nitrouz
Other Cars
Aug 15, 2008 03:12 PM
