That engine knock!
Left a gas station and immediately felt the car acting sluggish. (I always use Shell V-Power but this time i used Ultramar @ 91)
- I noticed the car getting hot (heat from engine bay) - Started knocking slowly then went crazy I hope it's the time chain tensioner... Any suggestion? Video: http://tucm.ca/vq35hr-knock.mp4 i'll scan the engine asap Thanks:icon43: |
why don't you just go back to using a Teir 1 gasoline and see if that solves the problem.
I always use 91 oct. I just used another BRAND.
If it's a Rod knock...i assume it's cheaper/faster to replace the engine.(?) |
well the way you phrased your question suggests that the issue is related to your use of Ultramar gas.
