Bolt went through Intake manifold?
Old Apr 7, 2019 | 11:24 PM
Serge Mullen's Avatar
Odd question, but I removed my engine cover recently and started the car. Well there was a pronounced hissing from one of the bolt holes in the intake manifold. This of course is causing a vacuum leak and the idle to jump around a bit. I'm guessing at some point someone used too long a bolt and punctured the manifold? This isn't somehow a design 'feature' right?
Once the cover is on and I have a bolt in, it appears to seal it and the car runs totally fine. Any issue with simply leaving it as is? On the plus side I suppose I can now run seafoam or other cleaners through there if i needed to clean the valves etc..
Old Apr 8, 2019 | 09:03 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Take a picture with your finger on the bolt that's hissing. The OEM engine cover bolt locations cannot hiss because they're on casting protrusions that are outside of any airspace.
Old Apr 14, 2019 | 01:49 AM
It may be normal, the one below it does not take any bolt as the engine cover is only secured by one bolt in the center.
Old Apr 14, 2019 | 10:48 AM
cleric670's Avatar
BANNED!!!
Ahhh I missed the part about it being an HR motor. I'm not too familliar with that upper plenum but just from looking at it it's definitely possible someone ran a longer bolt through and broke out the bottom of the casting. You would feel suction with your finger, if so then just add a rubber washer under the bolt or use a very light coat of teflon plumbing paste (don't recommend teflon tape) to seal the threads of that fastener.
Old Apr 14, 2019 | 08:53 PM
Thanks, i do have a rubber washer but can add some extra sealant on the threads although i dont think it leaks as is.
Old Aug 1, 2019 | 10:23 PM
lightmeupper's Avatar
G35X
Had same thing happen here. Didnt hear the hiss at first. I even did a throttle relearn. 1100 rpm is high compared to the factory 650 rpm. Im replacing valve covers before winter so I will see later whats under intake.
bigc
Intake & Exhaust
24
Mar 10, 2016 07:41 PM
c_morse
Engine - Intake/Fuel
Nov 2, 2013 11:24 AM
ATL_Red_G35
Picture Share
38
Sep 12, 2007 02:52 AM
WRAH
Jul 10, 2005 10:45 PM
