VVTI Solenoid P0011
Old Nov 18, 2022 | 06:38 PM
yellow's Avatar
Sedan
VVTI Solenoid P0011
tldr: Looking for Acceptable Ohm Range for VVTI Solenoid
edit: 2008 sedan,
I searched a bit on various sites as well as google, but I cant seem to find the acceptable range, this one tested in at 6.7 ohms
Old Nov 18, 2022 | 06:57 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
You may want to download the FSM for your car from NICOclub and follow the troubleshooting steps for that code, but here are the two steps for checking the IVT solenoid.
Old Dec 24, 2022 | 12:56 PM
yellow's Avatar
Sedan
Thank you for the FSM! I thought I had replied earlier this year thanking you, but i guess it didnt post.
Once the solenoid got up to room temperature, it tested at 7 ohms!
If anyone is curious, I ended up dropping the lower oil pan last night, and draining/filtering the oil as it came out in search of my oil gallery gasket,
Well, I found the paper gasket at the bottom of the oil pan, it was actually challenging to find, but it is confirmed, I will be needing my oil gallery gaskets replaced.
2008 Infiniti G35S 165k
Old Dec 26, 2022 | 12:38 PM
Joenavy85's Avatar
G35x Base
When I replaced my gaskets last year I found 2 fasteners that weren't even hand tight, just touching with a screwdriver made them turn, really glad I decided to change them out. While you're in there go ahead and change the timing chain guides and tensioner, as well as the water pump.
Justindiz
Engine - Electrical
Jul 25, 2016 11:01 PM
J2S2M
Media Share V36 Sedan
25
Jun 26, 2012 05:48 AM
mhleung
Mar 4, 2008 07:18 AM
YngPhllyKd
Jul 11, 2006 08:12 PM
