P0300 code
Old Apr 10, 2024 | 07:46 PM
jaydice's Avatar
Vq35HR
P0300 code
Car has multi misfire ( p0300 )
MY SYMPTOMS
Car misfires only low RPM (800-1.2k)
When i give the car light throttle to those rpm^ the car chokes and almost dies out, but anything higher then those rpms the car runs like a champ.
Also my A/F ratios are way off, and im also smelling gas.
PARTS IVE REPLACED
-o2 sensors -denso
-injectors -hitachi
-pcv valve
-fuel rail
-sparks - ngk iridium
-coils -hitachi
-ive smoked tested the car … nothing
Old Apr 13, 2024 | 10:43 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Did this just happen suddenly or did it start misfiring after you did some repair/upgrade/work on the car?
Old Apr 13, 2024 | 10:57 AM
jaydice's Avatar
Vq35HR
Started to do it after changing water pump , gally gasket, head gasket . But i only changed driver side head gasket. My fuel trims are way off on pass side though and no work was done on bank 1
Old Apr 13, 2024 | 10:59 AM
jaydice's Avatar
Vq35HR
Also the car was sitting for about 5 months , with a little less then 1/4 of gas. So i filled it with 93 and added some seafoam cleaner.
HyLowz
May 13, 2023 11:32 PM
Kennycaine
Jul 23, 2021 09:08 AM
willspencer04
Aug 5, 2020 10:40 AM
cfauvel
13
Oct 31, 2016 09:14 AM
jim9
Sep 14, 2012 02:27 AM
