Tpms?....
Old May 15, 2007 | 12:48 AM
SinCityG35's Avatar
Tpms?....
Can you disable it through the computer? I used to have an Audi and you can control everything through the vag com which is the serial port under the dash. Hell it even control the radio and headlights. I was wondering if these cars were as technologically advanced.
Old May 16, 2007 | 12:28 PM
Altersys's Avatar
dont know... but i'm curious: why do you want to?
Old May 16, 2007 | 04:17 PM
dopey's Avatar
i wouldn't mind having a way to disable it on demand so that the stupid light doesn't annoy me 4-5months out of the year that I have my snow tires on.
Old May 16, 2007 | 04:34 PM
SinCityG35's Avatar
Because I am getting wheels that do not accept the sensors.
Old May 16, 2007 | 05:23 PM
ttrank's Avatar
Grocery getter
Almost all wheels accept the sensors. You just have to use the "L" brackets to put the sensor inside the wheels and use the existing valve like I did with my volks.
As for your question, I know there is not on the earlier model and I doubt they changed that. It is a safety system and disabling it is a no-no. I know that discount tire won't even mount new wheels on my car if they don't have the sensors in them per corporate policy.
Old May 16, 2007 | 06:52 PM
imminence's Avatar
Do all tire installers know the correct procedures for mounting these sensors? And would we need to buy 4 new sensors for aftermarket wheels?
Old May 16, 2007 | 07:02 PM
imminence's Avatar
Do you have any pictures showing how you did that? Thanks!
Old May 16, 2007 | 07:29 PM
terrycs's Avatar
What also works (depending on wheel configuration) is to have a standard valve stem for filling and another hole drilled into the wheel just for mounting the TPMS in the inside wheel lip. Again, location depends on the shape of the wheel sections on a 3 piece or the barrel on a 2 piece.
Some people even band the sensor into the wheel and use a standard valve stem.
Old May 16, 2007 | 08:33 PM
SinCityG35's Avatar
are you talking about a strap kit? I have heard of them, but am not familiar with how they work.
Old May 16, 2007 | 08:34 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
hmm.... soo that's why Audi's are prone to having major electrical problems?!?!
-GP-
Old May 16, 2007 | 08:39 PM
SinCityG35's Avatar
I have never heard of that. Mine never did or any of the people I knew that had one.
Old May 17, 2007 | 02:23 PM
ttrank's Avatar
Grocery getter
I don't have any pictures because we did it in the bay at Discount Tire. I put them on. They are an "L" bracket that goes on the base of the valve that came on the wheel and the sensor hooks on to the other end making it parallel with the barrel of the wheel instead of perpendicular. So the sensor is completely inside the wheel. Discount had them in stock.
This is the same kind of idea but his used some kind of band. Mine were a lot easier.
http://www.350z-tech.com/zwiki/Tutor...rmarket_Wheels
Old May 17, 2007 | 02:28 PM
trey's wife's Avatar
My horns hold up my halo
Putting mine in the SSR's was a major PITA so I watched them do it. Until then I was not aware that it is basically part of the valve stem. They should be able to put them into any wheels that you have if you get new ones. As for not having it with the snow tires, I'm not sure what you would do. I have no idea on the '07 (because I kept mine) but on Trey's '05 he opted to NOT get the TPM's installed on his aftermarket wheels. His light is NOT on all the time. It still comes on occasionally but it is not on all the time driving you nuts or anything.
Old May 17, 2007 | 02:40 PM
spacecowboy's Avatar
a TPMS kit from tire rack costs 380 or so, but they say you can remove the TPMs from the stock tires and put them on whatever tire you buy.
Old May 17, 2007 | 04:59 PM
ttrank's Avatar
Grocery getter
$380 is a total rip off. You can call discount tire in Prescott, AZ and ask for Dale. See if the same kit ge got for Tim's Volks will work for you. He is a good friend and should be able to help.
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
