Wheel Lug Pattern
Old May 20, 2007 | 01:50 AM
JWise1203's Avatar
Wheel Lug Pattern
I am looking to purchase a 07 S Sedan 6MT. I currently have a 05 Sedan with a second set of stock wheels for Winter. I was wondering if anyone knew if the wheels my 05 would work on the 07? If so, I will use them as my Winter set. I am glad I didn't buy winter tires yet!
Old May 20, 2007 | 02:20 AM
GLuXuRy's Avatar
pretty sure the bolt pattern is the same
anyone else ?
Old May 20, 2007 | 10:00 PM
g35_6gear's Avatar
I test fit a spare set of 03.5 17" sport rims last week on the rear of my 07 Sport. It was reaaaaal close on the brakes on the back. I don't think anything less than an 18 would clear the fronts.
Old May 20, 2007 | 10:02 PM
trey's wife's Avatar
My horns hold up my halo
The bolt pattern is the same but, as stated above, there *may* be some clearance issues. When I put on my SSR's (they are 18's) I was shocked at how little clearance there was left for the brake calipers.
Old May 20, 2007 | 10:03 PM
GEE35FX's Avatar
Yes your 05 sedan wheels should fit your 07 G35 sedan.
Old May 20, 2007 | 11:26 PM
JWise1203's Avatar
So they were a close fit but worked right? I have the 18" sport wheels, so I hope I should be good then (I will have to test fit to be sure of course).
Old May 20, 2007 | 11:42 PM
Yes, they DID work but they are close - very close. lol
You should be fine with the 18's.
Old May 21, 2007 | 02:38 PM
psymonG35's Avatar
+1 I swapped mine ... one word of warning when you swap - you will have issue with the TPMS. If you have it done at the dealer ask them to reset the TPMS for the new rims otherwise it is another trip to the dealer! I know because I am on my way there now!
BlackGee35
Jul 31, 2015 11:04 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
