ECU Reset for 2007 G35 Sedan
Old Jun 1, 2007 | 01:50 PM
leliil's Avatar
How can one execute an ECU reset on the 2007 G35x Sedan? I searched the forums and have found some relating to previous years (ie: battery disconnect or gas pedal execution) ... Just trying to confirm if these methods will work for the 2007s in an attempt to improve my lovely gas mileage ... Thanks.
Old Jun 1, 2007 | 03:11 PM
Msedanman's Avatar
O.F. Administrator
I've not tried it on the '07 Sedan, but I have successfully done the identical procedure (Pedal method) on my M45 which has i-key.
Brush up on the procedure HERE first, and IMHO it should work....
Use post #3 (Merlin's)
Please post back with your results....& G/L
Colin
Old Mar 10, 2008 | 08:53 PM
jdanielsg's Avatar
I have read and post and TRIED to follow, my car now drives kind of funny... 1st and 2nd gear is always kinda jerky etc.
As per the post you mentioned.. if I want to reset the ECU do i need to do all the other stuff? the ones listed under it.. accelerator pedal something.. throttle something something ... LOL
Old Mar 11, 2008 | 02:20 PM
jdanielsg's Avatar
Anyone?
Old Mar 11, 2008 | 02:21 PM
dofu's Avatar
20 Year Member
I don't see why you would need to do an ECU reset... your ECU will relearn on it's own regrdless...
Old Mar 11, 2008 | 09:37 PM
jdanielsg's Avatar
not answering the question..............
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
kenthung
Jul 21, 2015 05:56 AM
