Question for the lowered guys (and gals?)-
Old Jul 23, 2007 | 02:12 PM
hokiesean24's Avatar
Originally Posted by terrycs
I noticed the tread feathering as well.
I'm not sure if I see anything rubbing on the aluminum part though. I would expect to see scuffing in an arc pattern. Can you take a look at the top side? I'm guessing that on heavy loading, its the top of the wheel that deflect inboard ... possibly rubbing on suspension components.
Yeah, you cannot really see in the picture, but it was definately rubbed/scratched in an arc pattern right there, I am not a great photographer. We didnt touch it though, it rubbed it clean/scratched it. I cannot see if anything hit at the top, I would probably have to take the wheel off to see up there.
Old Jul 23, 2007 | 02:14 PM
OK- so what can be done to limit this feathering??? Obviously the camber needs to be adjusted back into spec to eliminate it, I haven't been keeping up, what the status on the alignment kits?!?!
What about tire pressure, what are you guys running?!?!
Old Jul 24, 2007 | 01:45 PM
shaneotool's Avatar
This is just a guess here, but since you have stock diameter rear tires and less than stock diameter front tires, the car is leaning forward slightly - perhaps putting more weight/stress on your fronts than normal. Maybe for your next set of tires get some smaller rears or bigger fronts to level the car out.
Old Jul 24, 2007 | 03:43 PM
Altersys's Avatar
+2 on the feathering.
the only solution is to go back in spec on the alignment.
problem is, once feathering has begun on a set of tires, it doesn't go away until you replace the tire- unless it's VERY new. you said you have a good number of miles on the tires, right?
lowering without being able to get into alignment spec is like adding engine mods without tuning- it leaves you worse off than you were to begin with. i know you did it for looks, but try not to sacrifice that wonderful handling while you're at it.
Mry
Mar 3, 2023 01:03 AM
nervseele
Engine - Exhaust
Jan 17, 2016 01:02 PM
bTanz
Oct 15, 2015 02:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
CrazyLogic219
SouthEast
Jul 15, 2015 02:35 PM
