Convert XM to Sirius?
Old Sep 15, 2007 | 03:28 PM
cruzdog's Avatar
Is it possible to convert from XM Radio to Sirius without changing the whole radio? Any internal changes?
Old Sep 15, 2007 | 03:35 PM
Christian's Avatar
If you don't have navigation the XM radio tuner is separate from the head unit, so you should only need to replace that and the antenna. The tuner is number 5 and the antenna number 7 in the image below:
Old Sep 15, 2007 | 03:36 PM
cruzdog's Avatar
Just saw that - but it was kind of vague. I wonder if there is a "kit" somewhere or an audio store that can do the conversion using the oem equipment without messing with the antenna or getting a separate receiver.
Old Sep 15, 2007 | 03:39 PM
Christian's Avatar
The receiver and antenna are completely different and will need to be replaced, the only alternative is to install a portable sirius receiver.
Old Sep 19, 2007 | 01:54 PM
tagheuer's Avatar
Why don't you just wait a little longer until they formally merge (hopefully within the next 6 months) and then you won't have to change hardware at all.
Sirius and XM have guaranteed that the new combined company will broadcast signals that can be received by both existing types of hardware.
Old Sep 19, 2007 | 01:58 PM
Christian's Avatar
Last release I saw said that if you want the combined signal you need new hardware, but you can continue using xm hardware to get xm and sirius hardware to get sirius.
Old Sep 19, 2007 | 02:11 PM
cruzdog's Avatar
Interesting.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
orillyon
Oct 7, 2015 05:27 PM
JustinMKN1
Sep 18, 2015 03:40 PM
