Rear seat removal
Old Nov 30, 2007 | 03:39 PM
TLTONEY's Avatar
Rear seat removal
I need to remove the rear seat out of my 2007 sedan, but I can't find any info. Could someone please give me any tips or hints to make the removal go smoothly? Thanks in advance,
Trey
Old Dec 1, 2007 | 07:25 PM
silverG2007's Avatar
For the bottom, there are two plastic tabs that stick out slightly (where the seat hits the back of your knees). Pull the tabs towards the front of the car and the bottom of the seat will release.
From there, you should be able to see the screws that hold in the top.
Old Mar 25, 2008 | 01:52 AM
g35fromAZ's Avatar
Your post is older but I wont assume you have the answer yet..so
At https://g35driver.com/forums/showthr...70#post2812370
Are some pictures of my iPod Integration on my 2007 Sedan. In that installation I had to remove the backseat.(bottom)....very easy....pull the two black "circular" things and pivot it out from the back because on the back are two tabs that slip under the backs of the seat.
tiguy99
Mar 1, 2016 11:42 AM
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Aug 7, 2015 11:16 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Xanthan Gum
Aug 6, 2015 10:49 AM
