Quote:
if your engine gets sludged up and your using thier 5-10-15k synthetic oil thats your fault. Law suit?? NO! Why?... cause they are just gonna come back and say they support & recommend the fluid be changed out at the manufac. svc intervals. Efff whats printed on the bottle. thats just marketing.
No it isn't. The manufacturer recommended interval is typically BS but as mentioned, theres no sure fire accurate way to tell. If you're that paranoid about it, changing it too soon is better than changing it too late.Originally Posted by Ralph0064
funny thing, a mobil 1 rep came in a few months ago and he mentioned "they" recommend the oil get changed out at the manufactuers recommended intervals. SO...all the hype of 5-15k oil printed on the bottle is
the Castrol 0w-30 did have a green tint in it. My latest oil change had 3 bottles with tint and 2 newer bottles without tint - or at least not much tint. Same UPC and 'made in germany' on the lable. the newer bottles also were noted to meet an extra or newer MB oil standard.
I get the oil here in Fort Worth, TX at some autozones. Not all autozones here carry it. It doesn't last long when it's in stock.
I looked at the one on McCart and also Crowley Rd and had no luck, guess ill hit a few othersOriginally Posted by RikBakke
the Castrol 0w-30 did have a green tint in it. My latest oil change had 3 bottles with tint and 2 newer bottles without tint - or at least not much tint. Same UPC and 'made in germany' on the lable. the newer bottles also were noted to meet an extra or newer MB oil standard.I get the oil here in Fort Worth, TX at some autozones. Not all autozones here carry it. It doesn't last long when it's in stock.
Manufacture recommended is for regular oil I guess... if using Mobile 1, then you can go higher mileage with it.Originally Posted by Ralph0064
The rep must be wanting you to buy more from them and let them make more money.
A good way is to look at the oil via the dipstick every so often to see how clean the oil is, if it looks dirty then change it.
_________
2008 G35 journey5at ivory/stone+prem&sportpkg.
_________
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Positive Feedback100
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
[QUOTE=oughttoreturn]A good way is to look at the oil via the dipstick every so often to see how clean the oil is, if it looks dirty then change it.
Finally someone that uses his brain! If you use synthentic oil change it every
4K miles or when it looks dirty. If you don't care how your G35 runs it doesn't
matter when you change it, sell it to someone that does care....
since this is a 07+ thread, and if you care about warranty then you HAVE to change your oil at the stated intervals. If not warranty bye bye for your engine at least if there are issues down the road.
how long before you guys switch to synthetic...
I have kendall synthetic at my work for a good price but im thinking maybe of switching it over to synthetic after 10k miles.
I would wait till 10k miles.
_________
_________
I know for me, I'll be switching to synthetic and still following the manufacturer's 3,750 recommendation.
just me i guess, im sure a lot will disagree
I just converted to synthetic but then I had about 74000 miles.
Looked around, local tires plus uses Kendall and was about $45 (was $39 with paper ad). Then I found out Wal-Mart (yes Wal-Mart) had $49.99 and uses Mobile 1 synthetic. Got it changed in Wal-mart last Sunday. They don't take appointments so was tough to kill 90 minutes inside Walmart supercenter. Going through the threads here, Mobile 1 was more favourable and couple of my friends also recommended it.
I plan to go for about 7000 miles between changes. I can feel the car is running much smoother now. The tech said go for 5000-6000 miles but not more than 7000-8000 miles.
im determining for my first change if i want to use our inventory synthetic blend or go do outside purchasing on regular castrol oil since i work for a shop hmm.
I am switching to synthetic at my 15k service. I'm going with Royal Purple 5w-30 and a Purolator Pure One filter. I'm changing over to the schedule 2 service intervals 6mo/7,500 miles.
RP claims that going full synthetic, motor, tranny, and differential; reduces friction and increases HP, they claim roughly 5-10 whp. Couple of videos with before and after dyno runs to prove it. My service guy told me that Nissan already uses a synthetic tranny fluid. Not sure about the differential, but I'll probably change it out to synthetic at 30k.
Quote:
Here's a link to the videos. May be just all hype, you be the judge.Originally Posted by JayJay3452
what about royal purple?
http://www.royalpurple.com/rp-videos.html
I know RP is expensive, over $7 a quart.
