Pulstar Spark Plugs?
Old Mar 12, 2008 | 05:21 PM
AlexF's Avatar
Has anyone installed these yet? if so, any power gains that you can feel and/or gas mileage improvement?
Some previous threads where these have been discussed:
https://g35driver.com/forums/showthr...=pulstar+plugs
Old Mar 14, 2008 | 04:52 PM
07HRsedan's Avatar
dont need em,they worked well with the DE motors,the HR motor has iridium plugs factory.
Old Mar 15, 2008 | 12:52 AM
ddubb's Avatar
Exclamation
If any of you are interested in purchasing these use Coupon code 0031 to get a nice discount good through 4/1/08.
Beware: Pulstar™ Pulse Plug Model: DG-1 DOES NOT FIT on the HR motor.
I bought a set of these and used their website to select the 07 G35 with the HR motor. The part# comes back as DG-1. I went to install them this morning and the thread and nut size were too big. The stock plugs use a 15mm socket to remove. The DG-1's needed a 16mm. The problem is a 16mm socket doesn't fit in the plug shaft all the way down. I thought I was trippin and I took one out to compare and what do you know, the thread circumference was larger than stock. Had to put everything back together and chalk it up as a failed install. Now I'll be going back to Pulstar to let them know the plug is wrong, to correct their site and try and get a set that fits. Hey maybe they'll give me a set for free for the hassle.
Anyways, FYI...
Old Mar 17, 2008 | 02:31 PM
silverG2007's Avatar
From what I've read/seen on the internet. You'll get about 0-2% gains.
Not worth the risk/$$ IMO. They're like $25/plug.
Old Mar 17, 2008 | 02:36 PM
Iridium (and similarly platinum) is just going to make to make the plugs last longer. You're not going to gain any noticeable power or fuel economy.
Old Mar 17, 2008 | 08:26 PM
07HRsedan's Avatar
yes i know that
Old Mar 20, 2008 | 03:07 PM
stinky's Avatar
I thought Iridium was a better conductor than copper, unlike platinum, which is worse. Platinum is just for longer life, but Iridium may give a tiny performance boost.
100% pure copper (oxygen free) is a better conductor than iridium, but 100% pure copper is not achievable in a spark plug.
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
KallDay86
Jan 8, 2016 12:42 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
