Eibach vs. Impul
Old Apr 1, 2008 | 10:52 AM
MoCoG's Avatar
Originally Posted by hans127
I just got my Eibach's installed an 1hr. ago. Here are pics to compare the Impul drop vs. the Eibach Pro kit drop.
The First two pics are with Impul springs and the 2nd are with the Eibach Proz. From the photos you really can't see a huge difference, its def. more noticeable in person.
That Eibach drop is dead perfect. I'm ordering mine now
Did you install either of the Eibach alignment kits with them?
Old Apr 1, 2008 | 11:18 AM
brownfv's Avatar
OP took the pictures 1hr after install. the springs still need to settle...if he takes a picture a month from now it'll be lower.
Old Apr 1, 2008 | 11:31 AM
MoCoG's Avatar
As long as the front and rear settle about the same, I'm ok with that. I can't stand the a**-dragging look that Nissan/Infiniti seems to be fond of.
Old Apr 1, 2008 | 12:45 PM
brownfv's Avatar
+1 i dont like when the front is higher than the rear....if anything i would like the front to be a bit lower than the rear i think it gives a really aggressive stance.
Old Apr 1, 2008 | 01:01 PM
hans127's Avatar
Hey Mike
Originally Posted by 808MIKE
Looks good Hans! Yea wait till the springs settle, it will become a little lower. Compared to my Car with the Same Rims, the 19's are just below the Fender Lips, not tucked. Your's seems a little higher, So it should settle a little more!
Link for Pics with the Drop and Rims.
https://g35driver.com/forums/media-share-v36-sedan/204930-my-g-her-new-shoes-part-2-a.html
Looks like my car found his twin brother! yeah I think once it settles itll def. look a lot better!
Old Apr 1, 2008 | 01:04 PM
hans127's Avatar
If any of you were wondering...
I was trying to do a finger measurement for the front and rear. In the rear I can't put any fingers in the wheel arch, as for the front I can put just one. Just thought you wanted to know.
Old Apr 1, 2008 | 01:08 PM
hans127's Avatar
Hey MoCoG
Thanks for the comment! Yeah I wish I could see more Gs out there with the Eibach drop, its perfect...for those who desire a conservative yet a noticeably better handling vehicle.<just watch out 4 those big bumps).
To answer your question MoCo I did install the Eibach camber bolt. being that all I will need is about -1.5 degrees of camber for the rear, I really didn't see the reason to purchase the arm for 130.00...thats just me. With the Bolt you can get to about -3 degrees at most.
Old Apr 1, 2008 | 01:10 PM
UltimateGee27's Avatar
the impul doesnt look like it was even lowered. Whats the point of going thru purchasing, installation, alignment, for something that looks stock.
Did you notice anything difference in ride quality between the two?
Those G37 wheels look really nice
Old Apr 1, 2008 | 01:11 PM
hans127's Avatar
If you want the front to be lower,
I would suggest purchasing the H&Rz. Overall the drop is more aggressive and lower in the front than the rears. I think there also slightly cheaper than the Eibachs.
seagrasser
May 3, 2022 09:43 AM
Kelvin Style006
May 23, 2016 03:47 AM
erickLA
Aug 20, 2015 09:53 PM
kenthung
Jul 21, 2015 05:56 AM
