small quistion
Old Apr 8, 2008 | 08:15 AM
mr.g's Avatar
small quistion
do i have to re-program the computer if i want to put intake system in my car or no ? cause i heard if i dont i will get in trouble
thanx.
Old Apr 8, 2008 | 08:59 AM
Cabad85's Avatar
i assume when you mean computer, you mean the ECU. And for a simple bolt-on like that, you don't need to do anything but enjoy your new intake. happy modding!
Old Apr 8, 2008 | 12:55 PM
hyukki's Avatar
^+1
Old Apr 8, 2008 | 01:55 PM
mr.g's Avatar
Thanx very much
Old Apr 8, 2008 | 01:57 PM
UltimateGee27's Avatar
mr G make sure you disconnect the battery before you install the intake and make sure to reconnect the battery after the install is complete
Old Apr 8, 2008 | 03:22 PM
snowcrossmxz's Avatar
besides resetting the ecu(which is optional), Why does he have to disconnect the battery?
Old Apr 8, 2008 | 03:34 PM
because the high paying r&d people at Stillen and Fujita tell you to in the install instructions.....im not going to question those guys
Old Apr 8, 2008 | 03:52 PM
Im an EE by trade, and there is a dam good chance that I make more then they do.
There is no risk/benefit to disconnecting the battery for that type of install
If you actually talked to the R&D people, they would tell you this as well, It just a ploy that marketing injects to cover their ***.
Just like PIAA tells you right on the box not to use their bulbs on the road or highway.
To the op, if you want to disconnect you battery, there is no harm in it. You will have to reset your seat mem and radio presets...
If you don't disconnect you battery, your G could possibly explode, or just get up and run away.
Old Apr 8, 2008 | 04:03 PM
Phil Swagger's Avatar
quistion? lol jk. just put it in and go. some ppl get the CEL on but ive never gotten it. Im running fujitas.
Old Apr 8, 2008 | 10:54 PM
i wouldnt listen to snowcross
Old Apr 10, 2008 | 03:24 AM
mr.g's Avatar
Ultimate thanx for the advise but this is what im afraid of like what snowcross says but maybee more than that .
The reason ived asked cause one of my friend got a problem with his car when he put the intake and the problem is like when there is wrong with the injectors or with anythings that makes the car not normal like vibaration and so on.
Old Apr 10, 2008 | 07:28 AM
Cabad85's Avatar
Mr. G, I'm an EE as well and have a decent background on Marine diesel engines. Intake systems do not directly affect the internals of the motor, the only thing I can think of is an air leak after the mass air flow sensors which may cause vibrations/hesitations/shuddering/check engine light etc. As long as you follow the instructions of the installation by the manufacturer of the intake, you should be fine. Also, having a buddy help you out or just stand there and watch you do it should help. As soon as you get it installed, just start the engine and look in the engine bay for anything unusual such as vibrations, also have someone rev the engine after its been warmed up. If everything seems to be ok, go out for a test drive, don't mind the louder intake roar, thats normal. Hope this helps a bit more.
Old Apr 10, 2008 | 08:18 AM
^^^^ nice!
Old Apr 11, 2008 | 06:26 AM
mr.g's Avatar
thanx now i'm comfort
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
aaron3719
Sep 29, 2015 10:12 AM
