how to level the headlight on the 07 sedan?
Old May 15, 2008 | 05:05 PM
cup0spam's Avatar
I also cant find the screws. I'm literally typing this message in my garge with that service manual image in front of me. Anyone?
Old May 15, 2008 | 07:07 PM
FuzzyNips's Avatar
Alright, I did some more searching and found this thread with some pretty good pictures of what to look for:
https://g35driver.com/forums/showthr...ght=headlights
I used the pictures to find the big white 6 pieced pie shown in the first and second pictures. Look at where his thumb is on the second and third pictures. What you need is a #2 Philips screwdriver with a really long shaft so that it can make it down far enough to turn the gear. You stick the screwdriver through a hole on the black plastic piece covering the gear. The notches in the screwdriver "lock" into the notches on the gear and turning clockwise will raise the headlights and turning counter-clockwise will lower them. I was able to adjust the driver's side no problem but I can't get to the passenger side as there is a lot more stuff in the way.
Hope this helps!
Jusseth
Sep 13, 2020 12:25 PM
itgogitrev
Lights
May 2, 2016 06:53 AM
derres
Aug 28, 2015 03:27 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
RedBaronK
Jul 27, 2015 06:25 PM
