Mirror Covers w/ Signals /// Blacked Out No Emblem Grill
Old Apr 26, 2008 | 09:58 PM
UltimateGee27's Avatar
that grill looks crazy!
Old Apr 26, 2008 | 10:01 PM
hawaiinpunch's Avatar
nice work on the grill..came out great!!
Old Apr 27, 2008 | 12:54 AM
Replayray's Avatar
Great job on the grill and mirrors. I finished my LED signal mirror covers and they just came back from paint last Friday.
I will post up some pics late Sunday.
How did you get wiring into the doors? I came from the rear blinkers and I had to drill a hole in each kick panel for the wiring.
Other than that, it was really simple.
Old Apr 27, 2008 | 01:01 AM
Wicked_limitz's Avatar
i want the grill.
Old Apr 27, 2008 | 03:23 AM
razo168's Avatar
I will post next week.. sorry i've been really busy lately.. actually ill just send you the link for the pic so i dont have to post it. .but giev me a couple days..
the reason why i am changing them is i dont like how they look.. they WORK reallly well.. they just dont flow right. but the JDM is slimmer / flows better (evenly)
They dont fall out / sticks on between glass and lining..
PM me about the grill
Originally Posted by kool_yaar
Hey razo, i was about order the same visors, could you post a side view pic so i can see how the look, also why are you changing them?
Do they tend to fall out or something? Also does it just install between window and lining or is it stick on?
Also the car looks sick! PM me how much would u charge if i get the grill odne by you... im a bit tight on money but maybe down the road.
Thanks in advance!
Old Apr 27, 2008 | 11:44 AM
jdanielsg's Avatar
just wondering..since the mirrors are heated, shouldnt there be a wiring hole in the "sail" shaped trim going into the inside of the doors? Because the mirrors would most definitely have to be powered and heated..
And if I were to do this, i may ask a shop to do it and wire it to the stalk or steering column wires if possible for a much cleaner install do not have to breach firewall, since you guys mention theres no hidden side blinker wires.
Old Apr 27, 2008 | 11:55 AM
gary c's Avatar
Mirrors/Emblemless girlle....!
Not feeling the mirrors, too much bling for a coupe....But, the grille is sooooo
cool. After you guys have started this trend with the grilles you won't be able to find a used grille on the planet....Ouch! Good job....
Old Apr 27, 2008 | 12:02 PM
elayman's Avatar
^ I think he has an 07 sedan.. but maybe im wrong
Old Apr 27, 2008 | 05:55 PM
hyukki's Avatar
Damn, you beat me to it!
I was gonna do the grille just like that!
Looks very very good.
Old Apr 27, 2008 | 11:11 PM
Replayray's Avatar
The service manual mentioned that the BCM, Body Control Module, sends out the signals for the blinkers. Let me know if you need a link.
The BCM is mounted in the center console and should be easy to get to. The challenge is getting that signal up to the mirrors. That is why I had to drill a small hole in the kick panels from the dash area to the doors. I guess if you came from the front blinkers, you might be able to sneak wires without drilling. I found the flexible wiring harness near the door hinges to be moulded and not friendly to running two additional cables. I just ran the signal and ground behind the rubber cover near the door hinges.
Old Apr 28, 2008 | 08:41 PM
razo168's Avatar
buddy.. its a sedan.. and yeah i think its tacky for a coupe too..
PM me if you want to get ur grill done.
Old May 11, 2008 | 10:41 PM
07G35STQN's Avatar
can you tell me how to bypass the fog lamp
Old May 12, 2008 | 10:38 AM
airhoppz's Avatar
Those wheels are nasty! Running 20's?
Old May 12, 2008 | 11:05 AM
TheIvoryG's Avatar
Great job...like everybody said...the grille is great.
I love the idea of the mirrors, but for some reason they just don't flow right to me. The lights look like just stick out too much. I wonder why they didn't make them flow like the normal mirrow with the light built in smooth to the mirror.
Old May 12, 2008 | 11:14 AM
  #30
mbonus's Avatar
+1 on the grill - looks fantastic!
