question bout fogs
Old May 18, 2008 | 02:02 PM
narek330's Avatar
question bout fogs
guys for the fog lamps in the headlight on a 08g35x sedan do you think it would be ok to put in 50w hids with the kit or do you think that would use too much energy.
Old May 18, 2008 | 03:54 PM
EnviedG35's Avatar
U dont need a 50w hid in the fogs. You'll just blind people. 35w hid is plenty bright. And yes, you would still need a heavy duty harness for the ballasts. I hooked mine up to the stock wiring and it blew a fuse as soon as i turned the fogs on. And to change the fuse you have to take the battery out just to get to the fuse panel. Stock wiring just isnt sufficient for the power needed for the initial powering up of the ballast. It may last for a while, but sooner or later you'll wind up frying something if you dont use a heavy duty wiring harness for them.
Old May 18, 2008 | 04:16 PM
narek330's Avatar
well the reason i wanted to get 50w was because i wanted to get a exotic blue and the lumens on the 50w were 3300 but on the 35w they were 2200 so i mean it would make a huge difference..
Old May 18, 2008 | 04:17 PM
narek330's Avatar
so if i get the heavy duty wiring harness i could use the 50w one though?
Old May 18, 2008 | 05:34 PM
EnviedG35's Avatar
The fogs are aimed within a few feet away from the car. If you're doing the HIDs for the color then lumens arent really going to make a difference since the fog housing isnt made to throw light at a distance. Either way, you'll need some type of wiring harness.
Old May 18, 2008 | 07:28 PM
narek330's Avatar
thanks for that. that helped me out. question has anybody tried out the ipf hids or the retro solutions hids or efx hids,and does anybody know if there is a big difference in the mtec d2s replacment bulbs or xetronic hids replacemtn bulbs.?
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
maximino
Aug 12, 2015 02:05 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
