Stock wheel weight?
Old Sep 2, 2008 | 04:58 PM
Scooby24's Avatar
Stock wheel weight?
Has anyone taken the time to weigh our stock wheels to identify how much heavier or lighter aftermarket wheels are in comparison?
Old Sep 3, 2008 | 08:54 AM
snowcrossmxz's Avatar
not that i know of, but i would like to know this aswell,
you can get the weigh of just the tires from tirerack, i think the sport tires are around ~32 lbs each
Old Sep 3, 2008 | 08:57 AM
Scooby24's Avatar
I'll see if I've got some time tonight and will take off a front and rear wheel and weight the whole thing then.
Old Sep 4, 2008 | 03:35 PM
Scooby24's Avatar
I just got done weighing the wheels and I'm confused...
The front sport wheel and tire weighed 50.8 lbs. The rear sport wheel and tire weighed 50.4 lbs.
I triple checked the weights and even measured myself between each check to verify the scale was on and it didn't fluctuate even a bit. Every single time the weights were as above. I then verified the rear wheels were the wider at 8.5" and the front were the smaller at 7.5"
Tire weights as specified from tirerack are 27 for the front and 28 for the rear.
The front had 32.5 grams of balancing weight and the rear had 12.5
Therefore the front sport wheel weighs 50.8 (whole thing) - 27 (tires) - .07 (weights converted from grams to lbs) = 23.73 lbs
The rear sport wheel weighs 50.4 - 28 - .03 = 22.37 lbs
How an inch narrower front wheel can weigh 1.36 lbs more...I don't know.
Old Sep 4, 2008 | 03:50 PM
terrycs's Avatar
Probably just more metal in the mounting pad.
Old Sep 4, 2008 | 05:58 PM
nice work scooby
Old Sep 4, 2008 | 06:19 PM
silverG2007's Avatar
How many miles do you have on the car? Unless the tires are brand new, the math won't be exact.
My rear tires wore down much quicker than the front, so they'd weigh less with more mileage.
Old Sep 4, 2008 | 06:25 PM
Scooby24's Avatar
1600 miles...no burnouts or crazy driving that would wear the rear lower although that is a good point, I hadn't considered tire wear as a factor.
Old Sep 4, 2008 | 07:28 PM
TN G35S's Avatar
Good to know! Perhaps we can get someone to post this info in the first post of this thread: https://g35driver.com/forums/wheels-...s-offsets.html I think it'd be pretty relevant to a lot of people.
Old Sep 5, 2008 | 09:19 AM
^ agreed
Old Sep 5, 2008 | 09:31 AM
Scooby24's Avatar
check the last post in that thread ;-)
jsimonk
Dec 22, 2023 03:49 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
CJay
Aug 1, 2015 03:57 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
realtalk21
Jul 20, 2015 09:07 AM
