Is there any way to.
Old Dec 28, 2008 | 09:43 PM
G Wiz's Avatar
...disable all the maintenance indicators on the steering wheel console?
I grow tired of resetting them.
Old Dec 28, 2008 | 11:39 PM
TN G35S's Avatar
Yes you can disable them, but I forget the exact procedure. Cycle through the menu until you can go under maintenance. It's in there somewhere
Old Dec 28, 2008 | 11:48 PM
G Wiz's Avatar
I know you can disable the maintenance indicators on the center dash nav console, but I'm not sure about the steering wheel console.
I checked the manual....no luck.
Old Dec 30, 2008 | 07:49 PM
TN G35S's Avatar
Yes, it's possible with both. Like I said, go under maintenance and it has a reminder for engine oil, tires, other. You can set all of these reminders up to 18,500 miles intervals. After you get to 18,500 the next time you push the button the mileage goes to --. Once it's at -- the reminder is turned off.
You have to be sitting still in the car while you're doing this. Maybe that's where you're messing up.
Fox843
Nov 7, 2015 05:43 PM
gatorglaze
Sep 10, 2015 12:03 PM
CJay
Aug 1, 2015 03:57 AM
Lsantana757
Jul 20, 2015 09:08 AM
