ABS, VDC, SLIP lights ON and no power on G35
Old Dec 19, 2010 | 06:45 PM
awcima17's Avatar
I slammed my 2008 G35 sedan onto another's bumber while hitting the brakes really hard to avoid collision. No car external damage, but all of a sudden the ABS, VDC Off, SLIP, and "!" lights came on. Also the brake lights on the car's end are conctalty on, so I disconnect the battery to avoid a runoff. The car won't accelerate when i depress the gas to the floor and the max speed achievable is 50 to 65MPH. Anyone with same troubles after a collision?
Old Dec 19, 2010 | 07:11 PM
salvador312's Avatar
Welcome to the forum!!! I wish I could help you. Anyone else?
Old Dec 19, 2010 | 11:21 PM
pattyballs's Avatar
I had a very similar problem only i could only go 10mph. Had infiniti tow it and they said the problem was a cracked throttle body. Sounds very similar tho, i had all of the same lights. The only difference is my car could only reach 10mph. hope this helps and deffinitely try and bring it to a shop or dealer asap. Good luck
Old Dec 19, 2010 | 11:42 PM
kool_yaar's Avatar
This is the first time im hearing this, for patty it makes sense if it were the TB since he could not go over 10mph but i would be surprised if it were TB in your case as well considering it does get to 50-60mph.
Regardless of how hard you hit the brakes the car should not do that and should be covered under warranty considering its a big time safety hazard, whenever i hear anything like this i say the car went in limp mode where it does not react that quickly, however that should go away after a restart and cool down and should not keep you brake lights on.... take your car in and keep us posted.
Old Dec 21, 2010 | 05:37 PM
awcima17's Avatar
Smile ABS, VDC, SLIP lights ON and no power on G35 - Problem Solved
I couldn't pass the 20 MPH mark when initiating travel from a cold start! So it was pretty muhc like the problem observed by Patty. Anyhow, it was after a while that my car was able to reach 50-60MPH on thefreeway.
Old Dec 21, 2010 | 05:49 PM
awcima17's Avatar
I forgot to mention how I solved it. Well, I did kind of old school check (no OBD etc.). I went down and check/inspect the 2 switches on the brake pedal. One switch (i beleive it was the Stop Lamp Swaitch) seemed to be trigerring the brakes, and causing all this mess. I just pulled the switch, and adjust the brake pedal travel until it made contact with the switch... and the stop lights went off, and all the ABS/VDC/SLIP lights went OFF for good.
Cost of repair - just a couple of beers aferwards
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
Jusseth
Sep 13, 2020 12:25 PM
laksjd84
Jul 24, 2015 05:12 PM
