5AT Transmission Faluire?
Old Feb 28, 2011 | 01:19 AM
Bahg35's Avatar
Technical guys, need some input.
Last night i was driving my in manual mode, down shifts, up shifts, pretty spirited driving. I was slowing down so i started to down shift 4th, 3rd, 2nd, and held the gear there for a while, i kicked it shifted into 3rd, and all of sudden VDC, and SLIP lights came on. I put the gear back into D. drove slowly, and noticed that the transmission is acting gay, late shifts, and it shifts very hard, juss like an old skool V8 with a shift kit .
Pulled over turned the car off and on, Everything was normal. Nothing from what was mentioned above. Drove it around for 5 more mins as i was headin home it was totally fine.
Any one experienced this b4? I looked around and search, and found that wenever those lights are on. It means either BREAK FLUID, or BREAK PADS. But this doesnt explain the hard *** shifts i was getting in D mode.
Can anyone explain? should i b worried? should i take it to the dealer and get it checked out?
Any Feedback will be appreciated.
EDIT: Sorry forgot to mention, its an 08 G35 Sedan.
Old Feb 28, 2011 | 05:49 AM
kool_yaar's Avatar
Ya the lights are a result of the brake pads wearing out and causing the fluid level to drop as for the tranny to shift hard, i reckon it was doing that cause it "learned" that you were driving spirited and followed the suit when you popped it in D from what i have seen these trannies are quick learners, then when you reset the car it must have just gone to its default setting IMO.
if its driving fine now then i dont think that there is much to woory about, but then ofcourse i cant physically see your car and am just going by your description of the problem so if it gives you a piece of mind then you might as well get it checked out.
Old Feb 28, 2011 | 05:14 PM
Bahg35's Avatar
Thanks for the clarification.
I've been driving it since, nothin wat so ever but havent got the chance to try out M mode. I agree with u bout those trannys. But the shifts i was getting wen those lights popped up, it wasnt the shifts i get usually wen driving in DS. Ive driving my car for the past 3 years now. It never acted this way.
if it appeared again. I will go ahead and take it to the dealer, n get it checked.
Old Apr 29, 2011 | 09:18 AM
soltis007's Avatar
Any updates on this? Tranny ok? Like to know for 5AT users.
Old Apr 29, 2011 | 04:03 PM
Bahg35's Avatar
Well.. I took the car to the dealer earlier this month.
Scanned the code and it turns to be the Cam positioning sensor that is causing the car/Transmission to act this way.
At first i found that hard to believe. Replaced both sensors and some other wiring harness which i dunno of. And the car is running perfect since then. It even responses and shift smoother than b4.
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
Usman Ali
Sep 22, 2015 06:59 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
