V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Interior White LED lights
Old May 18, 2007 | 04:03 PM
  #31
G-Whizzer's Avatar
Pic link is bad...
Old May 18, 2007 | 07:07 PM
  #32
timn99's Avatar
Which link are you referring to?
Originally Posted by G-Whizzer
Pic link is bad...
Old May 29, 2007 | 11:12 PM
  #33
suby01's Avatar
i added piaa 168 bulbs which are the thicker 194s in the map light
:fruit first mods piaa map lights before (stock)
after :jawdrop
left piaa right stock
but my concern is that they do get a lot hotter, when i had these bulbs in my other car in the clear corners it melted the side markers.
any suggestions/comments.
Old May 30, 2007 | 01:14 PM
  #34
spacecowboy's Avatar
short of taking the lights out and sizing them, where can i find what are the right size leds? somwhere in the service manual?
Old May 30, 2007 | 02:12 PM
  #35
psymonG35's Avatar
Here is what I have installed into 3 2007 G35 Sedans - looks really nice. The generic bulbs are all the same (#194/168)
I ordered from SuperBrightLEDS
2 x WLED 4-LED bulb for Door (I have two cars with white, one with blue)
2 x WLED 4-LED bulb for License Plate
2 x WLED 4-LED bulb for Rear Reading Lights
2 x WLED 5-LED Wide Angle LED bulb for Map Lights
1 x WLED 5-LED Wide Angle LED bulb for Trunk (tried the 6-LED, but the 5 spreads light much better. )
Old Dec 24, 2008 | 04:19 AM
  #36
G35Tiko's Avatar
good site is www.v-leds.com
Old Dec 24, 2008 | 04:21 AM
  #37
G35Tiko's Avatar
2008 INFINITI G35
High & low beam headlamp
HID-D2S
Parking light
2827
Front turn signal
7440
Rear turn signal
7440
Tail light
LED
Stop light
LED
High mount stop light
LED
Fog/Driving light
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
License plate
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
2827
Rear sidemarker
LED
Map light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
158
Old Dec 27, 2008 | 07:10 AM
  #38
simsimi1004's Avatar
i got the WLED 4-LED from superbrightleds. after using the car and i turn the car off, the leds tend have power still goign to them. they have a "glow." (its off but it glows a bit)
is this normal?
g35x
Old Dec 27, 2008 | 06:06 PM
  #39
ketchupfreak's Avatar
is this normal?
g35x
Yup does it on mine and it hasnt harmed my car for 6 months now.
Old Dec 27, 2008 | 09:37 PM
  #40
Csquared's Avatar
it's normal only way to stop it is to turn the lights off.
Old May 23, 2009 | 01:47 PM
  #41
dohturdima's Avatar
I've replaced the door and map lights with LEDs from superbrightleds.com - noticed that the fadeout effect is no longer there (the lights just turn off when the door is closed). Is that something that was to be expected when replacing stock lighting with LEDs?
Old May 23, 2009 | 06:48 PM
  #42
Borna's Avatar
Most LEDs just turn off when you close the door instead of fading out because they use significantly less power than the stock bulbs.
Some members have said they still get the fade out though.
Old Aug 21, 2009 | 08:55 AM
  #43
Greekboy115's Avatar
I have my LEDs on the way kinda hoping I can still get the fade out but not expecting it at all. Can't wait to get rid of the yellow lights in there.
Old Aug 22, 2009 | 02:57 AM
  #44
Borna's Avatar
You probably won't even miss the fade out once you have them installed, they look so much better than the yellow lights.
Old Aug 24, 2009 | 08:22 PM
  #45
I just recieved my LEDs in the mail today. Just got done setting them up in fact and I still got the fade . Love the color vs. the old yellow. Best cheap mod I have done to date!
