V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
LED foglight and turn signal installed
Old Apr 7, 2008 | 10:29 PM
blueshirts0819's Avatar
Alright...took about an 2 hours but finally got it done. The reason it took 2 hours because I didn't have the right tool to take the bolt off from the intake housing. Needed a good torque wretch to loose that baby.
Took off the intake housing first and able to reach the lighting harness and unplugged them.
foglight-kinda hard to get out, tight space, scratch up my hand a little but unplug the bulb and put back the new one back into the housing.
turn signal- this is little tough and thank god I have also purchased the resistor with it or else the turn signal won't work (tried it before having the resistor). Connecting the resistor and wiring is quit simple but due to length of the wire is little more difficult. After connected the resistors I have to tie down the resistor some where (Because the resistor will get hot, avoid plastic area). For me, I had zip tied it on the front frame of the car.
After that, here is the before and after result. Little dissappointed with the foglight (little too dim) but turn signal is bright enough.
Here is the original link about using these light blubs.
https://g35driver.com/forums/v36-interior-exterior-lighting/211824-led-everywhere.html
Old Apr 7, 2008 | 10:42 PM
hawaiinpunch's Avatar
looks good
Old Apr 8, 2008 | 12:18 AM
_evilMonkey_'s Avatar
looks okay... since its LED, it has "dots" that makes the light but it looks really bright for LED light
Old Apr 8, 2008 | 08:33 AM
Robizzle's Avatar
Def get your parking light replaced it's LED 194 also. And IMO it was the biggest pain in the *** out of the 3.
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
as25656800
Aug 9, 2015 07:25 AM
MT6002
Lighting
Jul 21, 2015 01:13 PM
