V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Are metallic tints ok to use on the G?
Old Oct 8, 2008 | 10:29 PM
silverG2007's Avatar
For the naysayers, I did another "test" today.
With my windows down, I get better radio reception. The tint definitely seems to make a difference. Anyone know an easy (cheap) way to boost radio reception?
Old Oct 9, 2008 | 07:18 AM
soundmike's Avatar
Playing devil's advocate here... but that's a little odd to me. Isn't the antenna on the rear window? If that's the case, then it's being sandwiched by the tint on the inside and the glass on the outside. Having your windows open shouldn't make that much of a difference if the tint is causing poor radio reception since it's already being "blocked" on the inside. Thoughts?
Old Oct 9, 2008 | 10:00 AM
Virus's Avatar
AM reception is effected, not FM.
http://www.freewaytint.com/FAQ.htm
http://www.tintdude.com/totw92.html
Old Oct 9, 2008 | 02:12 PM
Originally Posted by Virus
Unless your FM antenna is located IN the rear windshield. (like our cars)
Metallic tint does not affect FM radio reception on vehicles with externally mounted antennas. It will affect AM reception, since the AM antenna (ferrite rod with coiled wire over it) is in the radio.
Old Oct 9, 2008 | 02:16 PM
Also, this is a note from your link: "This tip is NOT for other electronics such as GPS, XM radio, Wi-Fi, Cell Phone, etc., which are affected by the RF shielding capacity of a metal film."
The RF shielding will affect anything in its path. If the FM atenna is is the rear window.......
Old Oct 9, 2008 | 04:34 PM
Virus's Avatar
True, but our GPS antenna's are not located on the rear deck therefore signal is unaffected.
Old Oct 9, 2008 | 08:40 PM
Same is true for an external XM antenna. It wouldn't be affected.
Old Oct 10, 2008 | 09:16 AM
Virus's Avatar
Does anyone still listen to FM?
Old Oct 10, 2008 | 10:09 PM
soundmike's Avatar
Thanks guys. I went ahead with the metallics. 28 all around except the rear deck window which is 18%. The 28 has better heat rejection than the 35 ceramics, and the 18 has equal heat rejection as the 15% ceramic. I'm also glad to say there is no issue with AM/FM/XM/Nav/Bluetooth and cell.
Old Oct 12, 2008 | 02:56 PM
Virus's Avatar
Wow, that is quite shocking. My Huber Optic 40% rejects a ton more heat than my Diamond Marquise 35%. It's not even close.
Old Oct 13, 2008 | 08:47 AM
soundmike's Avatar
It may have something to do with the composition of the film itself. The tint shop i went two carried Jet (Llumar) and several Formula One tints--all of which were metallic, the heat rejection between them were noticeable - even if they were all rated at, say, 35%.
Old Oct 13, 2008 | 03:23 PM
Virus's Avatar
Did they have a heat lamp setup to show you the difference?
Old Oct 14, 2008 | 07:14 AM
soundmike's Avatar
Sort of, the tints were all on their window, facing the sun. Does that count?
Old Oct 14, 2008 | 07:50 AM
Virus's Avatar
No :-) Doesn't matter. It is of my opinion that metallic tints look better. I put Ceramic on the Minivan because it is the absolute best at keeping the interior cool. I chose Metallic for the G because it looks better.
Old Oct 14, 2008 | 04:10 PM
  #30
2008G35XSinMD's Avatar
I just got my windows tinted this past weekend and got
Sun-Gard 2 layer Metallic Sputtered film (Endurance 20). When I went to the tint place (United Solar) the metallic tints had the highest amount of solar energy rejection (Heat). I also never had a problem with my radio (XM, AM, FM), Garmin GPS or IPhone GPS, or Valentine 1 Radar (Friends, used for testing) or Escort 8500 Radar (Mine).
I had 4 preset AM stations and still get them 100% clear.
