Has anyone installed the KPTechnologies Electronic Beep module????
I do not know which wires to tap into at the BCM controller on the passenger side. There are about 3 different plugs, I've already hacked up one of them and tested the device and is does not work. I have searched and searched and have had a friend search and we cannot find anything or anyone else that has hooked up this device..
I was told from KP where to hook up which wires by colors at the BCM, however I was not told which adapter at the BCM it was as I mentioned above there is about 3 of them, some sharing the same colors within the same adapter.
Any advice is greatly appreciated as I have stopped working on it for tonight due to uncomfortable positioning in the car while trying to install this module...
blah..
Thanks.
blah..
Thanks.
Machine Head
Sep 4, 2015 07:22 PM
dimentio1
Aug 16, 2015 11:47 AM
beep, car, elecrtonic, electronic, factory, g35, install, installation, kp, kptechnologies, module, replace, technologies, wire
