V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
rear autokits diffuser installation problems! HELP!
Old Nov 30, 2010 | 07:33 PM
ckp's Avatar
ckp
ok so i installed the rear autokits diffuser and the double side tape on the right corner by the right exhaust tip on the corner where it curves isn't properly adhering to the car paint. what do i do to fix this? there is a picture below please help assap.
Old Nov 30, 2010 | 09:30 PM
kool_yaar's Avatar
The only right way to fix this would be to take it off clean the entire area with rubbing alcohol to get rid of any contaminants and wax, then reapply 3m double sided tape on entire diffuser and reinstall on a warm day and apply some painters tap on the corners to allow the adhesion to be firm and long lasting.
The quick and dirty way would be to get a piece of 3m tape and stick it in the gap and press together and apply some tape to hold in place and allow better adhesion for a few hours (i left it for a day). Or a NON-recommended but guaranteed way to keep it on would be apply some silicone sealant in the gap and pressing it together, but only do this if u are never planning to remove the diffuser, else taking the goo off will be a PITA though doable.
hope this helps.
Old Nov 30, 2010 | 09:38 PM
ckp's Avatar
ckp
^it def helps! i am going to try the silicone because I won't take the diffuser off it looks too good!
Old Jan 3, 2011 | 09:39 AM
djfarhan's Avatar
how did things work out man? i am getting mine in 2 days..
chinee
Jun 10, 2024 07:48 PM
atk08
Jul 30, 2015 03:12 PM
Soumilg
Jul 18, 2015 12:33 PM
newbdriver01
Jul 15, 2015 06:10 PM
