V36 Interior, Exterior & Lighting Interior & Exterior - Tech, Modifications, Lighting, Gauges and More
Center Arm Rest/Console doesn't close...suggestions??
Old Jul 13, 2012 | 04:58 AM
miesque1127's Avatar
I have a 2007 Sedan. The center arm rest with the leather cover will not close. The plastic latch is broken. Dealer wants almost $300 to replace it. Any suggestions on a cheaper fix?? Thanks....
Old Jul 14, 2012 | 12:35 AM
kool_yaar's Avatar
auto or mt? Im assuming you have automatic which has a different armrest assembly than the MTs.
Im sure you can find just the lock assembly for $20-30 used from a junkyard easy or check on ebay... I found one for the G37 which i THINK is the same for the auto sedan but since i dont have an auto i cant say for sure so please do your research before purchasing this or similar... Ebay G37 Latch
once you get the latch the install seems pretty straight forward where you remove the couple of screws off the old one and install the new one.
Hope it helps.
g/l
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
