Headlight issue...
Headlight issue...
Hello all...
I'm having an issue with my right headlight...both low & high are out. The bulb is good as well as both fuses. The same time it happened I noticed my auto up on all 4 windows is not working. Powers good on the windows and auto down works as well as everything else. Is there a relay tied in to the two that might have gone? Bad ballast and coincidence that my window issue occurred?? Also had the check engine light appear which I'm on my way to go run a diagnostics now.
'07 G35S Sedan
Thanks
'07 G35S Sedan
Thanks
The window issue happens to me randomly sometimes, try holding the button down for 5 additional seconds after the window is all the way down, then hold it up for 5 additional seconds after the window goes all the way up. This should re-learn the motors, and if it works you can isolate the headlight issue.
Also, low and high beam are the same light bulb. So if the bulb is fine i'd put my money on the ballast.
